Fault Code F1237 Reason
khoanvt
My UCS using version 3.1(3c, a fault appeared on one of the blade servers with a code of F1237
the full message is:
Health LED of server 1/6 shows error. Reason: Reason: P0V6_VTT_EF:Voltage Threshold Crossed;
Type: equipment
Cause: health-led-amber
Code: F1237
any suggestion to resolve this fault as I tried to search for a solution with no success.
Kirk J
connect cimc x/y (where x is chassis and y is blade number)
sensors
The look down through the output for something similar to :
Sensor Name | Reading | Unit | Status | LNR | LC | LNC | UNC | UC | UNR |
snip....
P0V6_VTT_EF | 0.566 | Volts | LC | 0.534 | 0.566 | na | na | 0.636 | 0.663
What is your 2nd column value?
Might want to try clearing your sel log, and rebooting the CIMC (reset CIMC from 'recover server' link)
See if the alert clears.
Recheck the sensors output to see if the reading value is lower or higher than the LC/LNC or higher than the UC/UNR set values.
Kirk...
khoanvt
Hi Kirk J,
I was did it. It working now. And i will monitoring about 1 week.
Thanks for help !
KhoaNVT
