Fault Code F1237
Abdullah Bawagih
Community Member
After upgrading my UCS to version 2.1(3a), a fault appeared on one of the blade servers with a code of F1237
the full message is:
Health LED of server 1/2 shows error. Reason: P3V_BAT_SCALED:Voltage Threshold Crossed;
Type: equipment
Cause: health-led-amber
Code: F1237
any suggestion to resolve this fault as I tried to search for a solution with no success.
-Abdullah
Abdullah,
The battery is below the "Lower Non-Critical" threshold, so yes, the battery needs replacement.
Open a TAC case with that output and there will no questions asked
Rate ALL helpful answers. Don't forget to mark the question as "answered" for other users in the future.
-Kenny
6 Replies 6
Keny Perez
Level 11
Level 11
Abdullah,
Welcome to the community!
That sensor makes reference to the CMOS battery on the server.  Could you please open an SSH session to the UCSM virtual IP address and run the following commands in bold?
B# connect cimc X/Y    X=Chassis  Y=Blade
[ help ]# sensors
The output will look something like:
CIMC Debug Firmware Utility Shell [ support ]
[ help ]# sensors
Sensor Name                | Reading | Unit          | Status     | LNR     | LC
P3V_BAT_SCALED     | 3.102     | Volts       | OK      | 1.993   | 2.416   <<<<<<<<<
P1V5_DDR3_P1           | 1.329      | Volts        | OK     | 1.212   | 1.280
At the bottom you can see what column means:
LEGEND:
LNR: Lower Non Recoverable Threshold
LC : Lower Critical Threshold
LNC: Lower Non Critical Threshold
UNC: Upper Non Critical Threshold
UC : Upper Critical Threshold
UNR: Upper Non Recoverable Threshold
na : Not available at this time or not applicable
If you see your battery is not within the acceptable ranges, then open a TAC case to have the battery replaced cause that is the only way to solve that low voltage issue.
-Kenny
Hi Keny,
Thanks for your response.
below is the output i got from the command you gave:
Sensor Name                | Reading | Unit        | Status | LNR     | LC       | LNC
P3V_BAT_SCALED       | 2.086     | Volts      | LNC     | na       | 1.993   | 2.416
P1V8_P2                      | 1.793     | Volts      | OK       | 1.617  | 1.705   | na
from the above, i believe there is an issue with the battery and it needs to be replaced!
correct me if im wrong and there is another solution.
Cheers,
-Abdullah
Abdullah,
-Kenny
I am seeing this Fault Code.  Where is this fault code mapping info?  It would be nice to be able to have a cross reference.
thanks,
Greg
