FCoE Northbound Connectivity ISSUES
marco.mosangini
Community Member
Hi all,
i've configured this topology for Ethernet and FCoE uplink from 6248UP to 5548UP:
Multi-Hop FCoE
When i check flogi database from n5k the result is:
  • n5kA --> no vfc to 6248A was logged
  • n5kB --> vfc to 6248B is up and running
This is sh int vfc21 (n5kA FCoE Po to 6248A):
vfc21 is down (Initializing)
    Bound interface is port-channel21
    Hardware is Ethernet
    Port WWN is 20:14:54:7f:ee:b2:fa:7f
    Admin port mode is F, trunk mode is on
    snmp link state traps are enabled
    Port vsan is 101
    1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      0 frames input, 0 bytes
        0 discards, 0 errors
      0 frames output, 0 bytes
    last clearing of "show interface" counters never
This is sh int vfc22 (n5kB FCoE Po to 6248A):
vfc22 is trunking
    Bound interface is port-channel22
    Port WWN is 20:15:54:7f:ee:af:49:bf
    Port mode is TF
    Port vsan is 102
    Trunk vsans (admin allowed and active) (102)
    Trunk vsans (up)                       (102)
    Trunk vsans (isolated)                 ()
    Trunk vsans (initializing)             ()
      740 frames input, 73824 bytes
        0 discards, 648 errors
      759 frames output, 132936 bytes
    Interface last changed at Wed Apr  3 09:32:57 2013
This is sh ru int vfc755 (6248A FCoE Po to n5kA):
vfc755 is trunking (Not all VSANs UP on the trunk)
    Hardware is Virtual Fibre Channel
    Port WWN is 22:f2:54:7f:ee:aa:cf:3f
    Admin port mode is NP, trunk mode is on
    Port mode is TNP
    Port vsan is 101
    Trunk vsans (admin allowed and active) (1,101)
    Trunk vsans (up)                       ()
    Trunk vsans (initializing)             (1,101)
    Interface last changed at Wed Apr  3 19:53:21 2013
This is sh ru int vfc756 (6248B FCoE Po to n5kB):
vfc756 is trunking (Not all VSANs UP on the trunk)
    Port WWN is 22:f3:54:7f:ee:aa:d2:3f
    Port mode is TNP
    Port vsan is 102
    Trunk vsans (admin allowed and active) (1,102)
    Trunk vsans (initializing)             (1)
    1 minute input rate 8 bits/sec, 1 bytes/sec, 0 frames/sec
      1187 frames input, 163868 bytes
      1930 frames output, 202972 bytes
    Interface last changed at Wed Apr  3 07:22:45 2013
Could someone help me solving this painful issue??
16 Replies 16
Jeremy Waldrop
Level 10
Level 10
What are vfc 755 and 756? Looks like there are 2 vfc bond to the same port channel? Send the output of these commands
show run | section "system qos"
show vlan fcoe
show run int vfc21
show run int vfc755
show run int po21
show int po21 fcoe
show fcoe database
  • vfc755 is vfc 6248UPA side (connected to vfc21 n5kA)
  • vfc756 is vfc 6248UPB side (connected to vfc22 n5kB)
The commands are the output from 5548UP-A
system qos
  service-policy type qos input fcoe-default-in-policy
  service-policy type queuing input fcoe-default-in-policy
  service-policy type queuing output fcoe-default-out-policy
  service-policy type network-qos jumbo
show vlan fcoe
Original VLAN ID        Translated VSAN ID      Association State
      101                       101              Operational
      4048                      1                Operational
show running-config interface vfc21
interface vfc21
  bind interface port-channel21
  switchport trunk allowed vsan 101
  no shutdown
show run int po21
!Command: show running-config interface port-channel21
!Time: Wed Apr  3 23:00:38 2013
version 6.0(2)N1(2)
  description UCS_FabIn_A_FCoE
  switchport mode trunk
  switchport trunk allowed vlan 101
  spanning-tree port type edge trunk
  spanning-tree bpdufilter enable
show int po21 fcoe
port-channel21 is FCoE UP
    vfc21 is Up
show fcoe database
INTERFACE       FCID            PORT NAME               MAC ADDRESS
swp01201#
Thanks in advance
M.
This is the connection topology:
n5kA-->po21-->vfc21-----------vfc755--->po21---6248A (not working correcly)
n5kB-->po22-->vfc22-----------vfc756--->po22---6248B (working correctly)
M.
I assume the FCoE VLAN on UCS Fabric A is 101?
Is the port-channel LACP?
send these command outputs from n5kA
show port-c summ
show int po21 trunk
show vsan 101
these from nxos on UCS Fabric A
show vlan fcoe
show port-c summ
show int po21 trunk
True.
n5kA# show port-c summ
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
        M - Not in use. Min-links not met
Group Port-       Type     Protocol  Member Ports
      Channel
1     Po1(SU)     Eth      LACP      Eth1/21(P)   Eth1/22(P)   Eth1/23(D)
                                     Eth1/24(D)
10    Po10(SU)    Eth      LACP      Eth1/5(P)    Eth1/6(P)
11    Po11(SU)    Eth      LACP      Eth1/1(P)
12    Po12(SU)    Eth      LACP      Eth1/2(P)
13    Po13(SU)    Eth      LACP      Eth1/3(P)
14    Po14(SU)    Eth      LACP      Eth1/4(P)
15    Po15(SU)    Eth      LACP      Eth1/17(P)   Eth1/18(P)
16    Po16(SU)    Eth      LACP      Eth1/15(P)
21    Po21(SU)    Eth      LACP      Eth2/11(P)   Eth2/12(P)
n5kA# show int po21 trunk
Port          Native  Status        Port
              Vlan                  Channel
Po21          1       trunking      --
Port          Vlans Allowed on Trunk
Po21          101
Port          Vlans Err-disabled on Trunk
Po21          none
Port          STP Forwarding
Po21          none
Port          Vlans in spanning tree forwarding state and not pruned
Port          Vlans Forwarding on FabricPath
Po21          none
n5kA# show vsan 101
vsan 101 information
         name:FABRIC_A  state:active
         interoperability mode:default
         loadbalancing:src-id/dst-id/oxid
         operational state:up
6248A(nxos)# show vlan fcoe
      4048                      1                Operational
      101                       101              Operational
6248A(nxos)# show port-c summ
      Channel
13    Po13(SU)    Eth      LACP      Eth1/19(P)   Eth1/20(P)
21    Po21(SU)    Eth      LACP      Eth1/27(P)   Eth1/28(P)
1025  Po1025(SU)  Eth      NONE      Eth1/1(P)    Eth1/2(P)    Eth1/3(P)
                                     Eth1/4(P)
1280  Po1280(SU)  Eth      NONE      Eth1/1/5(P)  Eth1/1/7(P)
1282  Po1282(SU)  Eth      NONE      Eth1/1/1(P)  Eth1/1/3(P)
1284  Po1284(SD)  Eth      NONE      Eth1/1/9(D)  Eth1/1/11(D)
1286  Po1286(SD)  Eth      NONE      Eth1/1/13(D)  Eth1/1/15(D)
6248A(nxos)# show int po21 trunk
              Vlan                  Channel
Po21          4049    trunking      --
Po21          101,4048-4049
Po21          none
Port          STP Forwarding
Po21          4049
Po21          --
at this point I am not sure what the issue is, everything looks correct from what I can tell. Usually when vfc is stuck in the initializing state the system FCoE QoS policies aren't applied but yours look ok.
Another command you can run to check the qos is "show run ipqos" the output should look like this
lab-n5k-a# show run ipqos
!Command: show running-config ipqos
!Time: Thu Apr  4 12:33:37 2013
version 6.0(2)N1(1)
class-map type qos class-fcoe
class-map type qos match-all test
class-map type qos match-all test-vlan
class-map type qos match-all match-all-traffic
  match cos 0-7
class-map type queuing class-fcoe
  match qos-group 1
class-map type queuing class-all-flood
  match qos-group 2
class-map type queuing class-ip-multicast
  match qos-group 2
class-map type network-qos class-fcoe
  match qos-group 1
class-map type network-qos class-all-flood
  match qos-group 2
class-map type network-qos class-ip-multicast
  match qos-group 2
system qos
  service-policy type network-qos fcoe-default-nq-policy
Configuration is exactly the same. In N5KB works correctly but in N5KA does not.
I've done another test: i've moved FCoE northbound to FC port-channel but issue was the same.
Marco
Ok, so it isn't an FCoE issue. Sounds like a VSAN/FC issue, do you have other devices or SAN connected to the Nexus over FC that are working? Anything in the flogi database for VSAN 101?
I've an FC tape drive connected to N5KA correctly inside flogi database. If I connect this trive to N5KA (VSAN 101 Fabric A) i couldn't see it from any blade. If i connect the drive to N5KB (VSAN 102 Fabric B) it's all ok. Comparing confs from nexus A and B the conf is exaclty the same (except VSAN 101 ID and FCOE VLAN ID).
In every blade that has a path to fabric A i saw this fault:
Affected object: sys/chassis-1/fabric-A/path-1/vc-815
Cause: link-down
Description: fc VIF 1 / 1 A-815 down, reason: NPV upstream port not available
M.
that typically means the NPIV feature isn't enabled. Did you check that?
N5KVA:
version 6.0(2)N1(2)
feature fcoe
hostname swp01201
feature npiv
feature fport-channel-trunk
feature telnet
cfs eth distribute
feature interface-vlan
feature hsrp
feature lacp
feature vpc
feature lldp
logging level flogi 5
N5KB:
version 6.0(2)N1(2)
feature fcoe
hostname swp01202
feature npiv
feature telnet
cfs eth distribute
feature hsrp
feature lacp
feature vpc
feature lldp
I don't know then, I think it is time to open a TAC case
Can you paste the output of
FI-A (nxos)
show run int e2/11-12
show int e2/11-12
show vsan database
FI-B (nxos)
show int e2/11-12
show vsan database
Robert
Also attach a "show run" from both N5Ks.  This is a config problem somewhere...
Robert
