FI & Nexus default connection mode with NSX
Yoobean Kwak
Our have configered FI to Nexus with NSX. it's mode Port-Channel mode.
Asking to balacing algorithm about following mode, what is a default mode ?
Wes Austin
You can run this command to check. Below outputs should be default on this code train:
FI-A(nxos)# show port-channel load-balance
Port Channel Load-Balancing Configuration:
System: source-dest-ip
Port Channel Load-Balancing Addresses Used Per-Protocol:
Non-IP: source-dest-mac
IP: source-dest-ip source-dest-mac
FI-A(nxos)# show version
<snip>
Software
BIOS: version 3.6.0
loader: version N/A
kickstart: version 5.0(3)N2(3.13b)
system: version 5.0(3)N2(3.13b)
Wes Austin
<snip>
Software
BIOS: version 3.6.0
loader: version N/A
