FI expansion module offline
Racso
Greetings,
We have a situation where the modules of our FI are offline, however the fixed modules are working as expected:
Mod Ports Module-Type                       Model                  Status
1   40    40x10GE/Supervisor                N10-S6200-SUP          active *
2   6     6x10GE Ethernet Module            N10-E0600              offline
3   6     6x1/2/4/8G FC Module              N10-E0060              offline
Fabric Card:
    Description: 40x10GE/Supervisor
    Number of Ports: 40
    State: Online
    Vendor: Cisco Systems, Inc.
    Model: N10-S6200
    HW Revision: 0
    Serial (SN): FOC15286MXD
    Perf: N/A
    Operability: Operable
    Overall Status: Operable
    Power State: OnLine
    Presence: Equipped
    Thermal Status: N/A
    Voltage Status: N/A
    Description: 6x10GE Ethernet Module
    Number of Ports: 6
    State: Offline
    Model: N10-E0600
    HW Revision: 0
    Serial (SN): FOC153256SR
    Perf: N/A
    Power State: OffLine
    Presence: Equipped
    Thermal Status: N/A
    Voltage Status: N/A
    Description: 6x1/2/4/8G FC Module
    Number of Ports: 6
    State: Offline
    Model: N10-E0060
    HW Revision: 0
    Serial (SN): FOC15322Q7C
    Perf: N/A
    Presence: Equipped
    Thermal Status: N/A
    Voltage Status: N/A
 The one we are worried about is the FC one that has the backup storage connections
When checking the UCSM, it appears as "operable", but we are fully aware it's not because all the storage paths through it have failed:
Any advice?
0 Replies 0
