get-ucsvnic and failover
nmohan001
hi, I am trying to find out if the vnic is set for fabric failover.. i don't see it under vnic... can someone point to me which cmdlet has that information. thanks
raja
nmohan001
ok, I found the answer just in case any one else is looking for the same.
Get-UcsServiceprofile -type instance  | Get-UcsVnic | select-object name, switchid
name                                                             Switchid
vNIC0                                                             A
vNIC0                                                             A-B
vNIC1                                                             B
  1. If the switch says “A” it is connected to FABRIC-A
  2. if the switch says B it is connected to FABRIC-B
  3. if the switch says A-B (A is primary) or B-A (B is primary) it is configured for fabric fail over
