Help setting up CICM IMC on the UCS-E module
dastrix80
Level 4
Level 4
H
i All,
How can i verify my SD cards are OK? I think the errors im getting are related to the SD cards.
I can open a session to the UCS-E but its stuck in recovery-shell, so i upgraded to 3.2.2 which it took OK but now I get these errors:
recovery-shell#  update 192.168.0.4 update_pkg-ucse-cimc.full.3.2.2.bin
downloading firmware image "update_pkg-ucse-cimc.full.3.2.2.bin" from "192.168.0.4"
download firmware image done, size in bytes: 40319916
installing firmware image, please wait ...
activating installed image
done
Stage: NONE
Status: SUCCESS
Error: Success
recovery-shell# reboot
NoteRestarting system.
CHIMP v1.3
Copyright Cisco Systems, Inc. (c) 2011, 2012
Attempting cisco_chimp_boot with FLAT_MMU algo
Divisor: 0x00000002
Checking if we are already running from PLL
Already running from PLL
Image 2 validation in progress
Image 2 validation COMPLETE
U-Boot 1.1.4 (Oct 27 2017 - 14:04:28)
U-Boot code: 87F00000 -> 87F21AB8  BSS: -> 87F26174
IRQ Stack: 87e9ff7c
FIQ Stack: 87e9ef7c
RAM Configuration:
Bank #0: 80800000 256 MB
Found SPI Chip Numonyx N28Q128
Flash: 16 MB
Using default environment
Net:   Phy Id 61e4  not matching dev_num is 0
Phy Id ffff  not matching dev_num is 1
pilot_eth0, pilot_eth1
Enable port 80 capture.
Type *** to stop autoboot:  0
Reading /dev/mtd2/boot.conf...Found boot.conf version 3
Writing pid:
Cisco Hardened Image Manager detected
Booting Linux2 from CHIMP
Running "run chimp2boot"
Boot reached stage 1
## Booting image at 008c0000 ...
Boot reached stage 2
Boot reached stage 3
   Image Name:   3.2(2.20171027140419)
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    7081376 Bytes =  6.8 MB
   Load Address: 80808000
   Entry Point:  80808000
   Verifying Checksum ... OK
Boot reached stage 4
Boot reached stage 5
Boot reached stage 6
OK
Boot reached stage 7
Boot reached stage 8
Boot reached stage 14
Boot reached stage 15
Starting kernel ...
starting pid 843, tty '': '/etc/init.d/rcS'
net.ipv4.tcp_tso_win_divisor = 8
net.ipv4.tcp_max_syn_backlog = 256
net.ipv4.tcp_max_tw_buckets = 256
net.ipv4.tcp_max_orphans = 8192
net.ipv4.tcp_rmem = 4096 87380 174760
net.ipv4.tcp_wmem = 4096 16384 131072
net.ipv4.tcp_mem = 12288 16384 174760
net.ipv6.conf.eth0.autoconf = 0
net.ipv6.conf.eth0.accept_ra = 0
net.ipv6.conf.eth1.autoconf = 0
net.ipv6.conf.eth1.accept_ra = 0
net.ipv6.conf.eth1_mac0.autoconf = 0
net.ipv6.conf.eth1_mac0.accept_ra = 0
net.ipv6.conf.eth1_mac1.autoconf = 0
net.ipv6.conf.eth1_mac1.accept_ra = 0
net.ipv6.conf.eth1_mac2.autoconf = 0
net.ipv6.conf.eth1_mac2.accept_ra = 0
kernel.core_pattern = /var/core/dumps/%t_%e_core.%p
kernel.core_uses_pid = 1
ldconfig: /lib/libpam.so.0 is not a symbolic link
modprobe: can't load module g_pilot3_nand.ko (kernel/drivers/bmc/nand_canis/g_pilot3_nand.ko): No such device or address
DEVICES                                                         [SUCCESS]
Updating the PCI Vendor ID.
Readback of Current PCI DID/VID
0000000         01011137
0000004
Write of new PCI DID/VID
Readback of New PCI DID/VID
0000000         01011137
0000004
Done
watchdogkick                                                    [SUCCESS]
mount: mounting /dev/mmcblk0p2 on /opt/flash failed: No such file or directory
od: /dev/mmcblk0p2: No such file or directory
rm: can't remove '/tmp/_flashfs.img': No such file or directory
Flash image verification failed for partition2
fdisk: can't open '/dev/mmcblk0': No such file or directory
Recovery mode, not starting services!
starting pid 1067, tty '': '/sbin/getty -L ttyS0 9600 vt100'
CISCO-IMC login: admin
Password:
login[1067]: root login on 'ttyS0'
recovery-shell#
dastrix80
Level 4
Level 4
Perhaps an SD card issue?
recovery-shell# sd-card format p4
Formatting parition 4
mount: mounting /dev/mmcblk0p4 on /mnt/datastore failed: No such file or directory
Hi dastrix80
I'm having the same issue, did you happen to know what the fix was ?
any help or advise would be greatly appreciated..
407169035
Visitor
