How to deploy UCS Nexus 5000 & SAN storage
sjahirud
Hi ,
I dont have good knowledge on nexus 5000 , but after going through lot of doc I am trying to setup UCS with nexus 5000 and san storage.
My objective is to boot server from san storage.
My setup :
UCS------>Nexus5000---------SAN storage
As per the document when I am configuring UCS for FCOE Uplink , there is no option to set the VSAN id.
I have created the VSAN 500 and then making one of the port in FI for FCOE uplink.Screenshot attached.
Plz let me know FI should be in endhost mode or switching mode..?I am running ucs 2.2(3d) version.
What kind of SFP should I use to connect from UCS & Nexus.
THanx & Regards
Shaikh
29 Replies 29
Did you create FC ports on the FI ? I assume you are using a 6248 or 96 ?
In the UCS Manager, go to the SAN tab, and there you can create VSAN's
Hi Walter ,
I configured from cli and its working.But facing issue with zoneset.Do you have any info to point.
And I want to deploy Nexus 5 k in load balancing mode.How can I do it...?
Shaikh
I mean two nexus 5k in load balancing mode.
Hi walter,
I have connected and configure the N5k.
I can see the floggi database and zone set
citywifi-n5k-1# sh flogi database
INTERFACE        VSAN    FCID           PORT NAME               NODE NAME
fc1/45           10    0x890020  50:0a:09:82:80:71:3f:67 50:0a:09:80:80:71:3f:67
fc1/46           10    0x890040  50:0a:09:81:90:71:3f:67 50:0a:09:80:80:71:3f:67
vfc142           10    0x890002  24:31:00:2a:6a:cd:49:bf 20:0a:00:2a:6a:cd:49:81
vfc142           10    0x890009  20:00:00:25:b5:00:00:37 20:00:00:25:b5:00:00:57
vfc142           10    0x89000a  20:00:00:25:b5:00:00:07 20:00:00:25:b5:00:00:27
Total number of flogi = 5.
citywifi-n5k-1# sh zoneset active vsan 10
zoneset name zoneset-citywifi-n5k-1 vsan 10
  zone name SCA-UCS-hba1-citywifi-n5k-1 vsan 10
  * fcid 0x890020 [pwwn 50:0a:09:82:80:71:3f:67]
  * fcid 0x890040 [pwwn 50:0a:09:81:90:71:3f:67]
  * fcid 0x890002 [pwwn 24:31:00:2a:6a:cd:49:bf]
But when trying to boot the ucs the message I am getting is
Emulex FCoE BIOS is not installed.
Please help me on this.
Q. What type of I/O adaptor are you using
Q. how many vha's and veth's does your service profile have
Q. what are the pwwn of your hba's
Q. which OS are you using
Q. could you install the OS ?
Q. what is your boot policy ? configured / actual ?
Hi Walter ,
Please find my topology :
Switch-1
citywifi-n5k-1(config)# sh flogi database
citywifi-n5k-1(config)# show zon
zone                   zone-attribute-group   zoneset
citywifi-n5k-1(config)# show zoneset active vsan 10
Switch-2
citywifi-n5k-2# sh flogi database
fc1/45           11    0x270020  50:0a:09:82:90:71:3f:67 50:0a:09:80:80:71:3f:67
fc1/46           11    0x270040  50:0a:09:81:80:71:3f:67 50:0a:09:80:80:71:3f:67
vfc141           11    0x270002  24:30:00:2a:6a:ba:8e:bf 20:0b:00:2a:6a:ba:8e:81
vfc141           11    0x27000b  20:00:00:25:b5:00:00:47 20:00:00:25:b5:00:00:57
vfc141           11    0x27000c  20:00:00:25:b5:00:00:17 20:00:00:25:b5:00:00:27
citywifi-n5k-2# sh ac
access-lists   accounting
citywifi-n5k-2# sh zoneset active vsan 11
zoneset name zoneset-citywifi-n5k-2 vsan 11
  zone name SCA-UCS-hba1-citywifi-n5k-2 vsan 11
  * fcid 0x270020 [pwwn 50:0a:09:82:90:71:3f:67]
  * fcid 0x270040 [pwwn 50:0a:09:81:80:71:3f:67]
  * fcid 0x270002 [pwwn 24:30:00:2a:6a:ba:8e:bf]
citywifi-n5k-2#
Q. which OS are you using : ESXI
Q. could you install the OS ?Its already installed on san storage, trying to boot it
Q. what is your boot policy ? configured / actual ? -
Something is not ok here:
This corresponds to fc0
It doesn't show up in the zoneset for vsan 10
This corresponds to fc1
It doesn't show up in the zoneset for vsan 11
Please correct your zoning and check, if you see your boot lun, and can install ESXi ?
Did you really have FCoE between FI and N5k; I would recommend to do FC, as your storage array is connected by means of FC !
Hi walter,
When I am booting the server I can see in nexus
Initial phase it was not there.when server boot with the service profile it automatically created.due to license issue in netapp we r using FCoE between FI & Nexus and FC between Nexus & Netapp.
Thanx walter ,
The problem with zoning , now I am able to boot the server from SAN.
Thanx a lot.
But I want to deploy Nexus 5000 in cluste mode.Plz help me how can I proceed...?
Hi Shaikh
Best practise:
From each UCS FI you have a link to each N5k, and create a LACP port-channel (and a vpc on the N5k). Therefore you have peerlinks between N5k; but this is Ethernet only.
For FC, the 2 N5k are totally isolated, no FC link in between. No dual homing of the FI's to the 2 N5k.
Regarding zoning, here a few useful commands
vsan database
  vsan 100 name "abc"
  vsan 101 name "xyz"
device-alias mode enhanced
device-alias database
  device-alias name 123456789 pwwn 00:00:00:00:00:00:00:07
system default zone distribute full
system default zone mode enhanced
zone mode enhanced vsan 100
zone mode enhanced vsan 101
!Full Zone Database Section for vsan 100
zone name BAL1-FA-WAN-A2-0W-BAL16-FA-WAN-A2-0W vsan 100
    member device-alias BAL1-FA-WAN-A2-0W
    member device-alias BAL16-FA-WAN-A2-0W
zone name BAL1-FA-WAN-A2-0W-BAL16-FA-WAN-B2-0W vsan 100
    member device-alias BAL16-FA-WAN-B2-0W
zone name BAL1-FA-WAN-B2-0W-BAL16-FA-WAN-A2-0W vsan 100
    member device-alias BAL1-FA-WAN-B2-0W
zone name BAL1-FA-WAN-B2-0W-BAL16-FA-WAN-B2-0W vsan 100
zoneset name BAL1-BAL16-FE-VPLEX-FA vsan 100
    member BAL1-FA-WAN-A2-0W-BAL16-FA-WAN-A2-0W
    member BAL1-FA-WAN-A2-0W-BAL16-FA-WAN-B2-0W
    member BAL1-FA-WAN-B2-0W-BAL16-FA-WAN-A2-0W
    member BAL1-FA-WAN-B2-0W-BAL16-FA-WAN-B2-0W
zone commit vsan 100
!Full Zone Database Section for vsan 101
Hi Walter ,
But n5k side I have not done any config , as per the guide first I need to configure from FI side , then I can proceed to n5k.
And can plz tel me how can I disable NPIV on FI in end host mode.NPV is end host mode and also NPIV also enabled.So I want to disable the NPIV in FI.
Shaikh
Have a look at
https://supportforums.cisco.com/discussion/11912046/configure-nexus-5548-native-fc
And one more thing is if I am using FC between FI & N5k , Then FI should be in switching mode.
I need to configure the port as FC storage port..?
Shaikh
No, FC will be in End Host Mode ! Yes, you need to create FC ports on FI and N5k !
