how to load ESX-i on UCS c260
miket
Level 5
Level 5
I have a very stupid question, how do you load ESX-i on a UCS c260. I have two controllers and 16 1tb drives.
I tried to put a USB Blue ray drive but no luck.
I couldn't get the virtual to work.
My 210's have DVD's  I am missing something
padramas
Are you able to access the server via CIMC and luanch KVM console ?
Are you planning to install ESXi on the internal Flexflash drive or hard disks ?
Couple of documents that will serve as reference.
http://www.cisco.com/en/US/docs/unified_computing/ucs/os-install-guides/vmware/CSERIES-VMWARE_chapter_011.html
http://www.cisco.com/en/US/docs/unified_computing/ucs/c/hw/C260/install/replace.html
Padma
padramas
Padma
Padma, I feel like an idiot, I forgot all about that. I read the book and i forgot. what a waste of your time.
But thank you . You are correct
