how to replace a secondary IO Module (2208XP) on a UCS Chassic
Curtis Hu
Level 5
Level 5
I couldn't find any Cisco document explain this procedure, does anyone know how to replace a IO Module (2208XP) on a UCS Chassic? From the UCSM, there's no option to decommession the IOM, do I just need to unplug the IO Module from the Chassic then put the new one in? Or there's any other step need to be taken.
Your response is appreciated, thanks
7 Replies 7
Walter Dey
Hi Curtis
In principle if service profile associated with a blade has dual fabric connectivity, and multipathing for Ethernet and FC is working properly, you could just remove and replace a IOM.
However, and I'm paranoid here, I would do it in a service window, or at least off hours.
see also
Installing and Removing a FEX or Fabric Interconnect
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/hw/chassis-install-guide/ucs5108_install/ucs5108_install_chapter_011.html
Thanks Walter, we have upgraded the UCSM, IOM and FI before, and there's no service inturruption at all. In that case, the multipathing should works the same when remove the IOM for a replacement?
Yes, of course; but their is a time window of around 10 minutes, where you only have one fabric in that particular chassis. And this is of course a single point of failure.
compton18
Any tips from your work? I am working on a 2104 to 2208 upgrade and looking into procedure and gotcha's at this time
This document should be beneficial:
UCS 2104 to UCS 2200 Series FEX Upgrade Considerations
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/hw/chassis-install-guide/ucs5108_install/ucs5108_install_chapter_011.html#ID225
Wes
Wesley,
Thanks for the doc, I was reading over that one and this one both of which have great information.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/upgrading/from2-0/to2-0MR/b_UpgradingCiscoUCSFrom2-0To2-0MR/b_UpgradingCiscoUCSFrom1-4To2-0_chapter_0101.html#d8429e1109a1635
Honestly is just seems too easy like there is more to it. I was hoping to fish out some real world hands on experience / gotcha's.
datance11
Hi Curtis,
i'm about to do a similar procedure with one IOM, but in my case, the devices that i have to remove is the one connected to the F.I. Primary. I'm looking for information of the procedure, but i couldn't find something that help me. Could you tell me the steps that you used?. Any recommendation?.
Thanks in advance.
Kind regard.
