Hyper V virtual fiber adapter not appear on Linux VM
I have ucs 2.2.6e. And we hyper v win 2012 R2 on the hosts
we create a Windows VM with 2 network ports and 2 fiber channel ports
then we successfully map a LUN to the VM after zoning the VM pwwn with the storage
Now we need to do the same with a Linux VM. That all the applications is on Linux
but on the Linux VM only the network ports appear and can ping the gw
but the problem is that the fiber adapter isn't appear so no ports available
We think it is driver issue
we tried the compatible cisco drivers for Linux but not help
I think the driver should be received from Microsoft as the network card type is hyper v and it is expected for the fiber channel adapter
so what do you think ?
thanks
7 Replies 7
Walter Dey
I don't think that Linux VM supports virtual FC !
see eg.
https://technet.microsoft.com/en-us/library/hh831413(v=ws.11).aspx
https://technet.microsoft.com/en-us/library/dn551169(v=ws.11).aspx
Updated: May 18, 2016
Applies To: Hyper-V Server 2012, Windows Server 2012 R2, Windows Server 2012, Hyper-V Server 2012 R2
The virtual Fibre Channel feature has the following prerequisites:
Virtual machines that are configured to use a virtual Fibre Channel adapter must use Windows Server 2012 R2, Windows Server 2012, Windows Server 2008 R2, or Windows Server 2008 as the guest operating system. No other guest operating systems are currently supported for use with virtual Fibre Channel.
Walter.
Hi Walter,
Thanks for your care and reply
Plz find link below
https://technet.microsoft.com/en-us/library/mt126277(v=ws.11).aspx
It is with newer date.
But the issue is that I can't find compatibility matrix between all the solutions [ UCS, Hyper-V and Linux ]
Do you think if we go with VM-FEX, it could help or we'll face the same issue . Or we should check with Microsoft bout this driver again. They insist that it is vendor issue but I see as I told before that Linux see Hyper-V as the vendor for the virtual cards
Haitham
Hi Haitham
I checked with MSFT gurus ! No one knows anything about future virtual FC support for Linux; it seems that SMB V3 is MSFT strategic storage protocol !
My personal experience with VM-FEX: mostly used in VMware environments! very seldom seen with Hyper-V.
Not clear if and when VM-FEX will become available with W2016 ?
What is your I/O requirement for the Linux VM ?
Cheers Walter.
Hi Walter,
Thanks again for your care
Cisco have a link for VM-FEX with Hyper-V configuration
http://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-manager/116374-configure-vmfex-00.html
our setup is each application is formed as cluster of 2 Linux VMs
So we install the 2 VM Linux OS
Then we need to Map a shared LUN for these 2 VMs only
We do so by zoning the VM fc ports pwwn ith the storage controller
Then on the storage, we assign a LUN for both VMs as a cluster
So it is zoned for both VMs only
The issue is that there is no  fiber channel adapter on the Linux VMs.
Haitham
Hi Haitham
Be aware, that VM-FEX is Ethernet only, no FC !
VM-FEX is implemented in a Windows Hyper-V environment with the use of Single Root I/O Virtualization (SR-IOV) and Intel Virtualization Technology for Directed I/O (VT-d) technologies.
With VM-FEX, you create dynamic vnic's, which are bypassing the hypervisor, and then can be attached to the VM.
With VM-FEX, you could use IP storage, eg. Linux with NFS !
Forget FC and Linux !
Walter.
Hi Walter,
Also I didn't find the link mentioning fc
but I think he say vNIC to represent both vNIC and vFC
So VM-FEX with VMware mention both vNIC and vfc ?
VM-FEX (for VMware, Hyper-V or KVM) is strictly only for Ethernet, not Fiberchannel.
In the UCS Service profile you have veth's (Ethernet) and vhba's (FC), and VM-FEX only refers to veth's.
see eg. thread
https://supportforums.cisco.com/discussion/11873456/vm-fex-and-nexus-1000v-relation
see also
https://blogs.technet.microsoft.com/jhoward/2012/03/12/everything-you-wanted-to-know-about-sr-iov-in-hyper-v-part-1/
Everything you wanted to know about SR-IOV in Hyper-V. Part 1 | John Howard – Senior Program Manager in the Hyper-V team at Microsoft
  1. John Howard -MSFT says:
    Suhani – SR-IOV Networking is not supported by Linux guests on Hyper-V at this time (as per my comment from Jan 2014 above).
