I have one question on Temperatures for UCS chassis modules/components
vKMR
Hi Team,
I have one concern on temperatures for my UCS chassis
Currently I am seeing high temperatures in UCS manager for motherboard and fan modules of my chassis
Current temp:
motherboard: 45 C to 47 C
Fan modules: 36 C to 38 C
As per our Cisco recommendations for temperatures for Chassis level is 10 C to 35 C
but I can not see any recommendations for individual modules/components
any idea on my request?
Thank you
Qiese Dides
Hi vKMR,
I have added 3 bullet points regarding this issue below, hopefully this will help you solve your question.
1) First thing's first I would like to make sure that the site-prep guide has been provided.  Make sure that this guide is followed and that you are current in compliance with the cooling related sections.
You will want to make sure that the back of the chassis especially is clear of obstruction including cables, if cables are not neatly arranged it can adversely effect your cooling capacity.
In order to make sure I understand at what point these readings are being collected please let me know where exactly these sensors are being placed front and rear.
Site Prep Guide:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/hw/zzOBSOLETE-site_prep/guide/siteprep_siteprep.html
2) To see all components temperature readings you can do the following, this will show you all components and if they are in an Okay state.
* SSH into UCS Manager
Fabric-Interconnect-A# connect cimc 1/1 (Chassis 1 blade 1)
Trying 127.5.1.1...
Connected to 127.5.1.1.
Escape character is '^]'.
CIMC Debug Firmware Utility Shell [ support ]
[ help ]# sensors <-- Run this command
Sensor Name      | Reading | Unit         | Status | LNR     | LC      | LNC     | UNC     | UC      | UNR     |
P3V_BAT_SCALED   | 2.990   | Volts        | OK     | na      | 2.011   | 2.403   | na      | 4.005   | na      |
P5V_STBY         | 4.965   | Volts        | OK     | 4.242   | 4.483   | na      | na      | 5.519   | 5.760   |
P3V3_STBY        | 3.239   | Volts        | OK     | 2.797   | 2.955   | na      | na      | 3.634   | 3.808   |
P1V1_SSB_STBY    | 1.077   | Volts        | OK     | 0.931   | 0.989   | na      | na      | 1.212   | 1.271   |
P1V8_STBY        | 1.756   | Volts        | OK     | 1.523   | 1.610   | na      | na      | 1.988   | 2.076   |
P1V0_STBY        | 0.970   | Volts        | OK     | 0.844   | 0.892   | na      | na      | 1.106   | 1.154   |
P1V5_STBY        | 1.474   | Volts        | OK     | 1.271   | 1.348   | na      | na      | 1.659   | 1.727   |
P0V75_STBY       | 0.718   | Volts        | OK     | 0.631   | 0.669   | na      | na      | 0.834   | 0.863   |
P12V             | 11.918  | Volts        | OK     | 10.797  | 11.269  | na      | na      | 12.685  | 13.157  |
P5V              | 5.008   | Volts        | OK     | 4.493   | 4.680   | na      | na      | 5.288   | 5.499   |
P3V3             | 3.276   | Volts        | OK     | 2.964   | 3.089   | na      | na      | 3.494   | 3.619   |
P1V5_SSB         | 1.482   | Volts        | OK     | 1.349   | 1.404   | na      | na      | 1.583   | 1.646   |
P1V1_SSB         | 1.092   | Volts        | OK     | 0.983   | 1.030   | na      | na      | 1.162   | 1.209   |
P1V8_SAS         | 1.767   | Volts        | OK     | 1.615   | 1.685   | na      | na      | 1.907   | 1.977   |
P1V0_SAS         | 1.022   | Volts        | OK     | 0.897   | 0.936   | na      | na      | 1.053   | 1.100   |
P1V05_VTT_P1     | 1.053   | Volts        | OK     | 0.944   | 0.983   | na      | na      | 1.108   | 1.154   |
P1V05_VTT_P2     | 1.053   | Volts        | OK     | 0.944   | 0.983   | na      | na      | 1.108   | 1.154   |
P0V9_PVSA_P1     | 0.866   | Volts        | OK     | 0.491   | 0.515   | na      | na      | 1.248   | 1.271   |
P0V9_PVSA_P2     | 0.897   | Volts        | OK     | 0.491   | 0.515   | na      | na      | 1.248   | 1.271   |
P1V8_PLL_P1      | 1.802   | Volts        | OK     | 1.615   | 1.685   | na      | na      | 1.907   | 1.977   |
P1V8_PLL_P2      | 1.790   | Volts        | OK     | 1.615   | 1.685   | na      | na      | 1.907   | 1.977   |
P1V1_VCCP_P1     | 0.718   | Volts        | OK     | 0.452   | 0.507   | na      | na      | 1.295   | 1.349   |
P1V1_VCCP_P2     | 0.718   | Volts        | OK     | 0.452   | 0.507   | na      | na      | 1.295   | 1.349   |
P1V5_VCCD_AB     | 1.498   | Volts        | OK     | 1.349   | 1.404   | na      | na      | 1.583   | 1.646   |
P1V5_VCCD_CD     | 1.498   | Volts        | OK     | 1.349   | 1.404   | na      | na      | 1.583   | 1.646   |
P1V5_VCCD_EF     | 1.498   | Volts        | OK     | 1.349   | 1.404   | na      | na      | 1.583   | 1.646   |
P1V5_VCCD_GH     | 1.490   | Volts        | OK     | 1.349   | 1.404   | na      | na      | 1.583   | 1.646   |
P0V75_DDR3VTT_AB | 0.745   | Volts        | OK     | 0.675   | 0.702   | na      | na      | 0.811   | 0.842   |
P0V75_DDR3VTT_CD | 0.745   | Volts        | OK     | 0.675   | 0.702   | na      | na      | 0.811   | 0.842   |
P0V75_DDR3VTT_EF | 0.749   | Volts        | OK     | 0.675   | 0.702   | na      | na      | 0.811   | 0.842   |
P0V75_DDR3VTT_GH | 0.749   | Volts        | OK     | 0.675   | 0.702   | na      | na      | 0.811   | 0.842   |
LEGEND:
LNR: Lower Non Recoverable Threshold
LC : Lower Critical Threshold
LNC: Lower Non Critical Threshold
UNC: Upper Non Critical Threshold
UC : Upper Critical Threshold
UNR: Upper Non Recoverable Threshold
na : Not available at this time or not applicable
3) How long has the server been up and running, and is this the only server having the issue? Is it constantly an issue or sporadic?
If it is constantly an issue (sensors show as NOT OKAY (gathered from step 2) and your server is not customized to run on high performance I would recommend opening a Cisco TAC case in which they may need to re-apply the heat sink.
If this assisted you please mark the post as correct so other members can help find these types of solutions.
- Qiese Dides
Hi Qiese,
Thanks for your response,
Yeah, I checked all status of sensors am we are fine there all time.
But I am little concern on high temperatures like 55 degrees C on motherboard of blade.
I am looking for a Cisco document which say's/shows exceptional values of temperatures thresholds for individual components [like fan modules, motherboard, PSU and etc..].
I now in general if the temperatures reaches 65 Degrees C the blade will go down
Thank you,
Sravan.
