07-05-2017 07:23 AM - edited 03-01-2019 01:14 PM
Hi All,
I have checked the mezzanine card and it is not installed.
The MLOM card is a "UCSB-MLOM-40G-03"
The blade just fails to inventory. I've tried decommissioning, resetting the CIMC but im thinking this is a hardware issue.
Can anyone advise?
Vince
Solved! Go to Solution.
07-05-2017 07:39 AM
The 2104 is not supported with VIC1340.
07-05-2017 07:29 AM
Can you confirm the IOM in your chassis?
Do you have other blades with the same hardware/software combination that are working without issue?
This error typically indicates unsupported hardware, whether its the blade or the IOM.
07-05-2017 07:36 AM
Hi Wesley,
IOM = 2104XP 2.2(8g)
No I have inserted two M4's and they both give this error, all other blades are B200 M3's.
07-05-2017 07:39 AM
07-05-2017 07:46 AM
Cool thanks for that.
Simple as replace the MLOM with a 1240?
07-05-2017 07:47 AM
Yeah, just make sure you decom the blade, replace the MLOM and then re-ack.
Update here if you face any issues or upon successful discovery.
Wes
07-05-2017 07:49 AM
Cheers dude. Will do.
