Issues Facing after using Inband IP KVM
andyblada1
Hello Gurus,
I am facing an unusual behavior in UCSM 4.0 (2b) while using inband KVM access.
Everything working fine, Service Profiles are getting IP from Inband Pool. Accessible and KVM launch is also working.
IP Pool Size is of 16 IPs and 3 are used by Service Profiles which make sense.
Rest 13 assigned to below address, And i don't know what it is.
sys/rack-unit-1/mgmt/iface-in-band/network/ipv4-pooled-addr
 sys/chassis-1/blade-2/mgmt/iface-in-band/network/ipv4-pooled-addr
I want to use remaining 13 IPs to another service profiles. Refer attached screenshot for details.
How to get rid of them.
Cheers
Andy!!
AFROJ AHMAD
Hi Andy,
Seems you are using "inband KVM mngmt" for the service profile because of that you are seeing these 13 new IP address assigned due to the 13 service profile.
If you wish to use only one IP address , please "set the KVM inband configuration" back to not set/None".
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Andy,
Thank you Afroj!!
Remaining IP's was picked by CIMC of each server. So i went to each server >> Inventory >> CIMC
Then "Change In band IP Address" and set not set/None.
And it worked. Thanks a lot !!
Cheers
Andy !!
