KVM console : after map drive and ctrl+alt+del does not see the drive present in virtual media
himadrel
HI ,
I am using UCS C220M4L and trying to load ubuntu. I see after mapping to CVD/DVD connections resets and then ubnutu image not visible in CD/CVD and even the boot sequence does not show any dvd mapped drive. I tried changin the different java verssion based on different threads but did not resolve the issue. Pasting the screenshot. I just tarted with UCS and very much beginner .
Question 1 : Am I using the correct ubuntu image (UCS version and ubuntu in the picture)?
Question 2 : I Followed https://www.youtube.com/watch?v=RlxQaPWJFUA to make the RAID but unable to see Cisco kvm mapped vDVD for loading. May I know if there connection drop from the KVM console or is it not able to make/upload the file itself ?
Based on the above data would you please help me to resolve this ?
Steven Tardy
From the screenshot the CIMC firmware is 2.0(13x) from 2016. . .
Modern browsers and old CIMC are often incompatible.
Get the latest firmware from:
  https://software.cisco.com/download/home/286281345/type/283850974/release/3.0(4r)
As you can't load a .iso via vMedia, you're in a catch 22.
Write the .iso to a USB drive and connect the USB drive and boot from the USB drive.
Alternately the CIMC and BIOS files can be extracted from the .iso image and uploaded directly to the CIMC Web GUI, but that is slightly more involved.
HI Steven,
Thanks for the reply!!
Due to COVID situation, no physical access available.
May I know if there anyway I can install the ubuntu hypervisor as that is my requirement? May I also know the Ubuntu file name I need to use (if not .iso) with this version and if there any link available to follow?
In worst case
HImanshu
