Low performance in FCOE TX in Nexus 5000
Dear Mister
I have a problem in the transmision of data. I have a Nexus 5000, using VFC(FCoE) toward FC ports. The ethernet with FCOE, also have IP traffic, and thsi traffic is functioning rigth, but, in the same wire, the FCoE show low performance.
How can I see the problems? The wire do not show CRC errors or another problems. The wire I saw OK. The only strange thing in the Nexus 5000, is at level qos discarded packet in the qos-group 1, this group is for FCOE.
I attachs the next :
NK5-AGG-SW02# show queue int e1/18Ethernet1/18 queuing information:
  TX Queuing
    qos-group  sched-type  oper-bandwidth
        0       WRR             50
        1       WRR             50
  RX Queuing
    qos-group 0
    q-size: 360960, HW MTU: 1500 (1500 configured)
    drop-type: drop, xon: 0, xoff: 2256
    Statistics:
        Pkts received over the port             : 6285
        Ucast pkts sent to the cross-bar        : 6260
        Mcast pkts sent to the cross-bar        : 25
        Ucast pkts received from the cross-bar  : 2920
        Pkts sent to the port                   : 2997
        Pkts discarded on ingress               : 0
        Per-priority-pause status               : Rx (Inactive), Tx (Inactive)
    qos-group 1
    q-size: 79360, HW MTU: 2158 (2158 configured)
    drop-type: no-drop, xon: 128, xoff: 252
     Statistics:
        Pkts received over the port             : 100813
        Ucast pkts sent to the cross-bar        : 100502
        Mcast pkts sent to the cross-bar        : 0
        Ucast pkts received from the cross-bar  : 106763
        Pkts sent to the port                   : 106763
        Pkts discarded on ingress               : 311
  Total Multicast crossbar statistics:
    Mcast pkts received from the cross-bar      : 77
NK5-AGG-SW02#   [15D [J
NK5-AGG-SW02# show queuing int e1/19
Ethernet1/19 queuing information:
  TX Queuing
        0       WRR             50
        1       WRR             50
  RX Queuing
    qos-group 0
    Statistics:
        Pkts received over the port             : 1034
        Ucast pkts sent to the cross-bar        : 1008
        Mcast pkts sent to the cross-bar        : 26
        Ucast pkts received from the cross-bar  : 2175
        Pkts sent to the port                   : 2251
    qos-group 1
     Statistics:
        Pkts received over the port             : 5092
        Ucast pkts sent to the cross-bar        : 5002
        Ucast pkts received from the cross-bar  : 2449
        Pkts sent to the port                   : 2449
        Pkts discarded on ingress               : 90
    Mcast pkts received from the cross-bar      : 76
The discarded packets means something??
I attach the configuration.
I will aprreciate your help.
Best Regards
dana.racine
Did you ever solve this? I am having similar performance issues.
A network diagram would be quite useful ? is it multihop FCoE, Storage connectivity with FCoE,......
