MDS 9148 compatibility With UCSM
andyblada1
Hello Team,
I am planing to upgrade CISCO MDS 9148 software from 5.0(xx) to 6.2 (xx) which is running with Cisco UCSM version running 2.2(6x).
Is there any compatibility matrix available to check the compatibility between MDS and UCSM. management software.
Walter Dey
see eg.
http://www.cisco.com/c/dam/en/us/td/docs/unified_computing/ucs/interoperability/matrix/b_hcl_B_rel3-11.pdf
and
http://www.cisco.com/c/en/us/support/servers-unified-computing/unified-computing-system/products-technical-reference-list.html
Thank You Walter for your swift reply!!
I have already gone through these links but no avail.
Could you please locate specific index which i can refer.
Table 10 of
MDS 9100, 9200,9500 Series:            4.2.1.      1,2,9,15
Notes
1 Code levels greater than or equal to these listed versions are deemed by Cisco to be interoperable
