Showing results forĀ
Search instead forĀ
Did you mean:Ā
MDS--Brocade issue
kakkargaurav
I have MDS and Brocade switch in the network scenario , suppose i have configured MDS 9124 with VSAN  and all the port licensed ports in MDS which are connected to BROCADE switch and also i am using Interop Mode 3 , so what configuration parameter should be on MCData 4700M ( like interop mode and  other configuration parameter) so that  ports on both sides should come.
Or could you please provide me the configuration for the both ends MCData 4700M and MDS 9124 so that ports on both sides should come up
rewilkin
gaurav,
Don't have a direct answer for you, but if you move this question over to Storage Networking, I am sure it will get answered, maybe Unified Computing is not the exact forum for your question.
