Monitoring Cisco UCS B200
lior.krispin1
hello everyone,
i need your help, with some questions  .
1. how i can to monitoring my UCS Blade? kind of software with lic or with no lic
2. how i can connect 2 chassis over the WAN (L2)  for one Management?
TNX
2 Accepted Solutions
Kirk J
Greetings.
You can use a number of products to monitor UCSM blades and rack servers.
One of the options is Cisco Prime Infrastructure.
A good place to start is the UCSM monitoring handbook at :https://communities.cisco.com/docs/DOC-37197
Most monitoring applications will have some kind of licensing or costs, but you may be able to find a few opensource solutions.
Your L1/L2 cables that connect a FI pair, need to be directly connected, and cannot be over WAN.
Kirk...
UCS Central will let you create globally define service profiles, pools, etc, so you can have a common management interface in UCS Central, once you join the 3 different UCSM domains to the UCS central.
UCS Central info can be found at http://www.cisco.com/c/en/us/products/servers-unified-computing/ucs-central-software/index.html
Kirk...
Kirk J
Greetings.
Kirk...
thank you very much for your help!
about L1\L2-
how i manage 3 chassis from 3 separated  different sites?
Kirk...
