Monitoring UCS
lior.krispin1
Community Member
hello,
can anyone recommend how i can to monitoring  UCS system?
hardware monitoring level like, fans, etc...
Thanks..
2 Accepted Solutions
Kirk J
Greetings.
See https://communities.cisco.com/docs/DOC-37197
Also on https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/mib/b-series/b_UCS_MIBRef/b_UCS_MIBRef_chapter_0100.html note:
Table 4 MIBs to Use for Gathering Statistics
Statistics Type MIB that Gathers the Statistic Statistics Table Name in SNMP
Ethernet
CISCO-UNIFIED-COMPUTING-ETHER-MIB
.1.3.6.1.4.1.9.9.719.1.16 is the parent OID where the key statistics reside.
etherPauseStats—Packet paused
etherLossStats—Packet loss
etherErrStats—Packet errors
etherTxStats—Packets transmitted
etherRxStats—Packets received
Adapter
CISCO-UNIFIED-COMPUTING-ADAPTOR-MIB
.1.3.6.1.4.1.9.9.719.1.3 is the parent OID where the key statistics reside.
adaptorEthPortBySizeLargeStats
adaptorEthPortBySizeSmallStats
adaptorEthPortStats
adaptorEthPortOutsizedStats
adaptorEthPortMcastStats
Fiber channel
CISCO-UNIFIED-COMPUTING-FC-MIB
.1.3.6.1.4.1.9.9.719.1.20 is the parent OID where the key statistics reside.
fcStatsTable
fcErrStatsTable
Blade and rack level
CISCO-UNIFIED-COMPUTING-COMPUTE-MIB
.1.3.6.1.4.1.9.9.719.1.9 is the parent OID where the key statistics reside.
computeMbPowerStats—Provides all motherboard power statistics for every blade.
computeMbTempStats—Provides all motherboard temperature statistics for every blade.
Rack level
computeMbPowerStats—Provides all motherboard power statistics for every blade. computeMbTempStats—Provides all motherboard temperature statistics for every blade.
Processor
CISCO-UNIFIED-COMPUTING-PROCESSOR-MIB
.1.3.6.1.4.1.9.9.719.1.41 is the parent OID where the key statistics reside.
processorEnvStats—Provides all CPU power and temperature statistics for every CPU socket.
Equipment
CISCO-UNIFIED-COMPUTING-EQUIPMENT-MIB
.1.3.6.1.4.1.9.9.719.1.15 is the parent OID where the key statistics reside.
equipmentFanStats—Provides all statistics for every physical fan in every chassis in a UCS domain.
equipmentFanModuleStats—Provides all fan module temperature statistics for every fan module in every chasis in a UCS domain.
equipmentChassisStats—Provides all chassis level temperature statistics for every chassis in a UCS domain.
equipmentPsuStats—Provides all chassis level power and temperature statistics for every power supply in a UCS domain.
equipmentIOCardStats—Provides all chassis level power and temperature statistics for every fabric extender in a UCS domain.
Memory statistics
CISCO-UNIFIED-COMPUTING-MEMORY-MIB
.1.3.6.1.4.1.9.9.719.1.30 is the parent OID where the key statistics reside.
memoryUnitEnvStats—Provides all memory DIMM temperature statistics for every memory module.
Switching statistics
CISCO-UNIFIED-COMPUTING-SW-MIB
.1.3.6.1.4.1.9.9.719.1.46 is the parent OID where the key statistics reside.
sysEnvStats—Provides all fabric interconnect level power statistics for every fabric interconnect in a UCS domain.
Kirk...
Walter Dey
Hi Lior
https://de.slideshare.net/Ciscodatacenter/ucs-central-best-practices-for-single-and-multi-ucs-domain-management?next_slideshow=1
and
https://communities.cisco.com/community/technology/datacenter/compute-and-storage/ucs_management/blog
gives a good overview what's available.
Kirk J
Greetings.
Ethernet
Adapter
adaptorEthPortStats
Fiber channel
fcStatsTable
fcErrStatsTable
Rack level
Processor
Equipment
Memory statistics
Kirk...
hello,
thanks, i mean to Cisco software for monitoring....
You want to configure callhome to send e-mail alerts for certain errors and events.
Smart Call Home Quick Start Configuration Guide
Configuring Call Home
You setup the UCS to forward e-mails to your SMTP server and you can indicate individual or e-mail alias in the profiles.
Walter Dey
Hi Lior
and
