N20-C6508 UCS 5108 Blade Svr AC Chassis/0 PSU/8 fans/0 fabric e
alisakhi029
I have Cisco UCS 5108 and trying to install Cisco UCS 6324 Fabric Interconnect for the configuration purposes. I can't boot it normally. it's give ma message of non-supported.
5 Replies 5
Hi Wes Austin, Thank you for the rapid response. Appreciate it. Could you also guide me if I don't have 5108-AC2, what would be other option to run the 5108 UCS along with M4 blades?
Thanks & regards,
You would need a UCS Fabric Interconnect 6100, 6200, 6332* or 6400 model with appropriate firmware to support the B200-M4s.
Hi Austin,
I managed to run Cisco mini UCS on 5108-AC2 chassis. However, when I assigned an IP address to the Mgmt, It doesn't open the GUI interface. could you please guide?
You can probably access the UCSM setup using HTTP (http://10.10.2.8) instead of HTTPS. Otherwise, just setup UCS from the CLI.
