Nexus 1000V interfaces not forwarding
Martin Jaburek
Hi all,
I have a problem, that interfaces shows as up, but it does not actually work - it doesn't work.
When I tried vemcmd show port:
LTL   VSM Port  Admin Link  State  PC-LTL  SGID  Vem Port
   18     Eth4/2     UP   UP    F/B*      0        vmnic1
   49      Veth7     UP   UP    FWD       0        vmk0
   50     Veth13     UP   UP    FWD       0        Nexus1000V-4.0.4.SV1.3d.eth2
   51     Veth12     UP   UP    FWD       0        Nexus1000V-4.0.4.SV1.3d.eth1
   52     Veth10     UP   UP    FWD       0        Nexus1000V-4.0.4.SV1.3d.eth0
   53      Veth1     UP   UP    FWD       0        uda20.eth0
   54      Veth8     UP   UP    FWD       0        Nexus1000V-4.0.4.SV1.3d (Second
   56      Veth3     UP   UP    FWD       0        Nexus1000V-4.0.4.SV1.3d (Second
* F/B: Port is BLOCKED on some of the vlans.
How can I found out which vlan is blocked?
5 Replies 5
mipetrin
Hi Martin,
If you wish to verify what vlans are on each port, execute:
# vemcmd show port vlans
It is normal to see that statement about BLOCKED vlans, if you are not allowing all possible vlans.
You stated that it doesn't work. What symptoms are you seeing to say it doesn't work?
From your output, it is only reporting for vmnic1.
What vlans are you allowing on the upstream switch port connected to this vmnic?
The port-profile for this vmnic allows which vlans?
If you could be more specific about what isn't working, we can help.
Michael
Hi Michael,
my setup is that I have two servers connected via switch (which does not understand vlans), essentialy I have only one data vlan 104. The whole setup was working, but then I tried upgrade to 4.2.1(4a) and now I lost connectivity to that vlan (VMs and VSM mgmt0)
Maybe the problem is with the native vlan on that trunk (here it says number 1):
[root@exs-x86demo9 ~]# vemcmd show port vlans
                        Native  VLAN   Allowed
  LTL   VSM Port  Mode  VLAN    State  Vlans
   18     Eth4/2   T        1   FWD    5,10,104
   49      Veth7   A      104   FWD    104
   50     Veth13   A       10   FWD    10
   51     Veth12   A      104   FWD    104
   52     Veth10   A        5   FWD    5
   53      Veth1   A      104   FWD    104
   54      Veth8   A       10   FWD    10
   56      Veth3   A        5   FWD    5
and configured port-profile for eth4/2:
port-profile Rack4Uplink
type: Ethernet
description: taggedUplink
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport mode trunk
  switchport trunk native vlan 104
  switchport trunk allowed vlan 5,10,104
  no shutdown
evaluated config attributes:
  no shutdown
assigned interfaces:
  Ethernet4/2
  Ethernet6/1
  Ethernet6/2
port-group: Uplink_Rack4
system vlans: 5,10
capability l3control: no
capability iscsi-multipath: no
port-profile role: none
port-binding: static
I just added vlan 104 to the system vlans section on the Rack4Uplink and now it works. But I don't know why it should not work...? (show module showed all modules and both VSMs)
interesting thing is, that now the command show port vlans display the native vlan correctly as 104:
                        Native  VLAN   Allowed
   18     Eth4/2   T      104   FWD    5,10,104
   52     Veth10   A        5   FWD    5
   56      Veth3   A        5   FWD    5
  305        Po1   T      104   FWD    5,10,104
Hi Martin,
I can see that you have configured the control VLAN as 5, management as 104, and packet as 10.
The control VLAN is where most of the communication takes place, that allows the VSM to see the VEM (as in your output of show module).
In your initial configuration, you correctly defined the control and packet VLANs as system vlans. However, the management VLAN should also be a system VLAN to ensure that it is always forwarding (even after a reboot of the VSM and prior to it coming back up), as this is an important VLAN for you to manage the VSM itself. Although, this is mainly important when the VSM is behind a VEM. In this scenario, if you don't define it as a system vlan, then you can run into traffic disruption as you have experienced.
Further details regarding system vlans and their use can be found in previous posts on the forums. Good place to start:
https://supportforums.cisco.com/thread/2012512
Michael
