Showing results forĀ
Search instead forĀ
Did you mean:Ā
package empty in default host firmware
Amr Hafez
Hi All
I received this minor error and do not Know what is this
Manuel Velasco
Hi Amr,
The reason you see this message is because you have the "Firmware Auto Sync Server policy" set to "auto Acknowledge" or "User Acknowledge" (see screenshot below) and the default host firmware package policy has some empty values.   To clear this fault you can fill out the empty values in the default host firmware policy or what I would recommend is to set the "Firmware Auto Sync Server policy" to "No Actions".
Let me know if this helps.
