09-27-2019 11:33 PM
hi Team , my rackmount servers are directly connected to switches
| Cisco Nexus Switch 31108 A | Eth 1/3 | Cisco UCS C220 C-Series Standalone Server A | MLOM1 | port 0 |
| Eth 1/4 | Cisco UCS C220 C-Series Standalone Server B | MLOM1 | port 0 | |
| Eth 1/5 | Cisco UCS C220 C-Series Standalone Server A | MLOM2 | port 1 | |
| Eth 1/6 | Cisco UCS C220 C-Series Standalone Server B | MLOM2 | port1 |
| Cisco Nexus Switch 31108 B | Eth 1/3 | Cisco UCS C220 C-Series Standalone Server A | MLOM3 | port 2 |
| Eth 1/4 | Cisco UCS C220 C-Series Standalone Server B | MLOM3 | port 2 | |
| Eth 1/5 | Cisco UCS C220 C-Series Standalone Server A | MLOM4 | port3 | |
| Eth 1/6 | Cisco UCS C220 C-Series Standalone Server B | MLOM4 | port 3
now i have put Eth1/3 from both switches into PO13 and eth1/4 from both swicthes into PO14 . after which my IPs were not reachable , so i changed the nic teamimg policy to IP hash after which my IPs are reachable but there is packet drop . now i have shut PO 14 on bith switches and my first host IP is pinging fine no packet drop ... and if i shutdown the PO 13 then 2 nd IP working fine ... should eth1/5 , eth1/6 also be part of Port channel PO13 , PO14 ?
09-28-2019 01:07 AM
I prefer to look at your port-channel config of both the side switches
is the nexus 3K connected each other vPC with peerlink?
how about configuring vPC down the UCS environment.
show suggest better and test, post the configuration of the switch side.
09-28-2019 02:18 AM
09-28-2019 03:16 AM
how is your spanning-tree configured?
Just to make more clear, when you bring other port-channel you getting Packet drop, once you shutdown that Port-channel all traffic is good - is this correct?
Can you post the configuration as suggest in the last post
