Partition bootflash on fabric interconnect A is clean but with errors
jettacone
I have this issue on both FIs after an upgrade.  I am going to run the command
connect local-mgmt (a|b)
(local-mgmt)# reboot e2fsck
I will do this on the subordinate first.
Question:  Is it wise to first evacuate via the GUI before running this command, even though it is on the subordinate?
Also once the FI is back up and all connections are verified, should i run the cluster lead command to switch to the subordinate before running the e2fsck command on the primary?
Thanks in advance!
Rod T
Kirk J
The evacuation is per FI, so simply evacuate the specific FI you are getting ready to reboot.
That is fine to do the lead change prior to rebooting (what was the Primary).
Please keep in mind that fabric evacuations do not apply to directly connected C series/Rack servers.
Kirk...
