Port Channel uplink trunk between FI 6248 and Dell S4808 (Force 10) won't come up.
mark.werner
I have been attempting to bring up a port channel between a Cisco 6248 Fibre Interconnect and a Dell S4808-ON. I cannot get the channel to come up. I am not sure what I am missing. Hoping to find some help or suggestions here.
The Dell S4808 is a bit of a bird of a different feather when it comes to configuration. It runs a Dell Networking Operating System (DNOS) which is derived from Force 10 Operating System (FTOS). Nevertheless, As far as I can tell it is configured accordingly to support an LACP channel.
I ran the following commands on the switches to provide results to present for review.
First from the Cisco Fibre Interconnect:
show interface Ethernet 1/17 brief
show interface Ethernet 1/17 transceiver
show interface port-channel 17
show running-config
Second from the Dell S4808-ON:
show interfaces tengigabitethernet 3/17
show interfaces tengigabitethernet 3/17 transceiver
show interfaces port-channel 17
(conf-if-te-3/17)#show config
(conf-if-po-17)#show config
show lacp
Cisco-FI-A-A(nxos)# show interface Ethernet 1/17 brief
Ethernet      VLAN    Type Mode   Status  Reason                   Speed     Port
Interface        Ch #
Eth1/17       1       eth  trunk  down    Link not connected          10G(D) 17
Ethernet1/17 is down (Link not connected)
Dedicated Interface
  Belongs to Po17
  Hardware: 1000/10000 Ethernet, address: 00de.fb03.2098 (bia 00de.fb03.2098)
  Description: U: Uplink
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
 Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped never
  30 seconds input rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    0 unicast packets  0 multicast packets  0 broadcast packets
    0 input packets  0 bytes
    0 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    0 output packets  0 bytes
    0 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
  0 interface resets
Cisco-FI-A-A(nxos)# show interface Ethernet 1/17 transceiver
Ethernet1/17
    transceiver is present
    type is SFP-H10GB-CU3M
    name is CISCO-LOROM
    part number is LRHSPB54D030
    revision is B2
    serial number is LRM194981E7
    nominal bitrate is 10300 MBit/sec
    Link length supported for copper is 3 m
    cisco id is --
    cisco extended id number is 4
Cisco-FI-A-A(nxos)# show interface port-channel 17
port-channel17 is down (No operational members)
  Hardware: Port-Channel, address: 0000.0000.0000 (bia 0000.0000.0000)
  MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, auto-speed
  EtherType is 0x8100
  Members in this channel: Eth1/17
  RX
    0 Rx pause
  TX
    0 jumbo packets
    0 Tx pause
  0 interface resets
Cisco-FI-A-A(nxos)# show running-config
interface port-channel17
  description U: Uplink
  switchport mode trunk
  pinning border
  switchport trunk allowed vlan 1,10
  speed 10000
feature npv
feature npiv
interface Ethernet1/17
  pinning border
  channel-group 17 mode active
  no shutdown
leaf2#show interfaces tengigabitethernet 3/17
TenGigabitEthernet 3/17 is up, line protocol is down
Hardware is DellEth, address is 64:00:6a:f2:56:34
    Current address is 64:00:6a:f2:56:34
Pluggable media present, SFP type is 1000BASE-T
Interface index is 4196356
Internet address is not set
Mode of IPv4 Address Assignment : NONE
DHCP Client-ID :64006af25634
MTU 1554 bytes, IP MTU 1500 bytes
LineSpeed auto
Flowcontrol rx off tx off
Last clearing of "show interface" counters 13:50:23
Queueing strategy: fifo
Input Statistics:
     0 packets, 0 bytes
     0 64-byte pkts, 0 over 64-byte pkts, 0 over 127-byte pkts
     0 over 255-byte pkts, 0 over 511-byte pkts, 0 over 1023-byte pkts
     0 Multicasts, 0 Broadcasts, 0 Unicasts
     0 CRC, 0 overrun, 0 discarded
Output Statistics:
     0 packets, 0 bytes, 0 underruns
     0 throttles, 0 discarded, 0 collisions, 0 wreddrops
Rate info (interval 299 seconds):
     Input 00.00 Mbits/sec,          0 packets/sec, 0.00% of line-rate
     Output 00.00 Mbits/sec,          0 packets/sec, 0.00% of line-rate
Time since last interface status change: 7w6d17h
leaf2#show INTerfaces tengigabitethernet 3/17 transceiver
Interface Name                 : TenGigabitEthernet 3/17
SFP is present
SFP 1114112 Serial Base ID fields
SFP 1114112 Id                       = 0x03
SFP 1114112 Ext Id                   = 0x04
SFP 1114112 Connector                = 0x22
SFP 1114112 Transceiver Code         = 0x00 0x00 0x00 0x08 0x00 0x00 0x00 0x00
SFP 1114112 Encoding                 = 0x01
SFP 1114112 BR Nominal               = 0x0c
SFP 1114112 Length(SFM)    Km        = 0x00
SFP 1114112 Length(OM3)    2m        = 0x00
SFP 1114112 Length(OM2)    1m        = 0x00
SFP 1114112 Length(OM1)    1m        = 0x00
SFP 1114112 Length(Copper) 1m        = 0x64
SFP 1114112 Vendor Rev               = A
SFP 1114112 Laser Wavelength         = 25.85 nm
SFP 1114112 CheckCodeBase            = 0x33
SFP 1114112 Serial Extended ID fields
SFP 1114112 Options                  = 0x00 0x12
SFP 1114112 BR max                   = 0
SFP 1114112 BR min                   = 0
SFP 1114112 Vendor SN                = PX804CD
SFP 1114112 Datecode                 = 170221
SFP 1114112 CheckCodeExt             = 0x6a
SFP 1114112 DOM is not supported
leaf2#show interfaces port-channel 17
Port-channel 17 is up, line protocol is down(minimum links not up)
Created by LACP protocol
Hardware address is 64:00:6a:f2:56:34, Current address is 64:00:6a:f2:56:34
Interface index is 1258299904
Minimum number of links to bring Port-channel up is 1
LineSpeed auto
Input Statistics:
     0 packets, 0 bytes
Output Statistics:
Time since last interface status change: 5d22h29m
leaf2(conf-if-te-3/17)#show config
interface TenGigabitEthernet 3/17
no ip address
port-channel-protocol LACP
  port-channel 17 mode active
  lacp port-priority 1
no shutdown
leaf2(conf-if-po-17)#show config
interface Port-channel 17
no ip address
portmode hybrid
switchport
lacp fast-switchover
lacp long-timeout
no shutdown
leaf2(conf-if-vl-10)#show config
interface Vlan 10
description VLAN on x.x.x.x /24 lab network
name Lab VLAN 10
ip address x.x.x.x/24
tagged TenGigabitEthernet 3/3,3/6-3/8,3/11-3/16,3/19-3/24
tagged Port-channel 2,17
untagged TenGigabitEthernet 3/1
no shutdown
leaf2#show lacp
% Error: Incomplete command.
cswp-leaf2#show lacp 17
Port-channel 17 admin up, oper down, mode lacp
LACP Fast Switch-Over Enabled
Actor   System ID:  Priority 32768, Address 6400.6af2.5632
Partner System ID:  Priority 0, Address 0000.0000.0000
Actor Admin Key 17, Oper Key 17, Partner Oper Key 0, VLT Peer Oper Key 17
LACP LAG 17 is an individual link
LACP LAG 17 is a normal LAG
A - Active LACP, B - Passive LACP, C - Short Timeout, D - Long Timeout
E - Aggregatable Link, F - Individual Link, G - IN_SYNC, H - OUT_OF_SYNC
I - Collection enabled, J - Collection disabled, K - Distribution enabled
L - Distribution disabled, M - Partner Defaulted, N - Partner Non-defaulted,
O - Receiver is in expired state, P - Receiver is not in expired state
Port Te 3/17 is disabled, LACP is disabled and mode is lacp
Port State: Not in Bundle
  Actor   Admin: State ADEHJLMP Key 17 Priority 1
           Oper: State ADEHJLMP Key 17 Priority 1
  Partner is not present
LineSpeed auto
Input Statistics:
     0 packets, 0 bytes
Output Statistics:
Time since last interface status change: 5d22h43m
Kirk J
Greetings.
Not sure if this is mentioned in your output, but have you confirmed the individual ports come up outside of the port-channel?
Looks like at least one or both of the dell output lists a 1000Mb SFP, but your FIs show 10Gb SFPs.
Please confirm you can individually bring up the trunk links to make sure we have any media/sfp/issues ironed out first.
kirk...
