Power management functionality UCS C
rortigosa
Community Member
How do I  configure power management on a Cisco UCS C220 M3 alone host and C200 M2  too?
I Need that information for configure a fence agent and hardware settins on RHEV
5 Replies 5
rortigosa
Community Member
Please help me, I not know how to do it
Thanks so much. It was very usefull to me.
The above information is now outdated.
Version 4.1 of Red Hat Virtualization is current and the referenced Red Hat documentation link is a broken URL.
How can IPMI or cisco_ucs fence agents be used with this series of hardware,  Cisco UCS C220 M3 ?
ssedmak
Community Member
Not sure if it's still the issue for you - but here's I resolved it. It's a bit dirty workaround and redhat is already working on it.
You need to setup hexadecimal-encoded key for IPMIv2 authentication which is set on CIMC IPMI over LAN settings via Admin>Communication services as first thing.
Then you need to modify /sbin/fence_ipmilan file.
So, backup /sbin/fence_ipmilan in-case you need to replace it back
1) Please edit: /sbin/fence_ipmilan (with your favourite editor)
2) Move to line number 35, and add following just below the line:- cmd = options["--ipmitool-path"]. cmd += " -y (your hex key here)"
For reference, the ipmitool command that worked was as below:
~~~ # ipmitool -I lanplus -y $(hexadecimal-encoded Kg key for IPMIv2 authentication) -H <192.168.0.x> -U USERNAME -P PASSWORD -L Administrator chassis power status
Chassis Power is on
Then in RHV GUI > Hosts > Edit host > Power Management > Add/Edit agent .. and you need to add following options..
lanplus=true,power_wait=4
Good luck 😉
