PRI channel busy issue , even when there are no active calls
aslam.bajwa
Level 3
Level 3
Hi All ,
i using VWIC-2MFT - E1 CARD with VG. one PRI is working fine but on another PRI we are facing busy channel problem , even when there is no active calls , actually channels are not being free after disconnecting call. when we restart the gateway its startworking for some time ...
i already replaced that card .
please advice
David McFarland
I believe that this post should be made to the Unified Communications and Video forum.
Would please you repost to that group.
