Problem to get Link on Nexus5548UP
pslavkovsky
I have SFP-LH-SM in eth1/1 in Nexus5548UP but I have problem to get LINK on eth1/1.
I have SFP-LH-SM in eth1/1 in another Nexus5548P and it is not  problem to get LINK with same configuration of eth1/1
Is there some special setting for Nexus5548UP?
Is there diferent settings on interface on Nexus5548UP and Nexus5548P ?
Peter
Oleksandr Nesterov
Can you please try to remove SFP module, then configure speed:
interface x/x
speed 1000
then insert the SFP back.
Also try to repeat this using SFP that works on 5548P
HTH,
Alex
vek64gware
Just a crazy idea, but it can be that your port configured to be an FC port.
