Repairing Local Blade Storage RAID-1
terran0925
I've been performing failover testing with our UCS and can't quite figure out how I can repair a RAID-1 configuration for the blades' local storage.  What I did was pull one of the SAS drives out of a the blade then reinserted it.  The LED is lit up as yellow and for some reason UCSM doesn't outline that server as having any problems.  The only indication I can see within UCSM is if I navigate to the inventory tab, then the storage tab and look at the "Disk 2" section.  Everything in there is listed as unknown.  Is this normal?  Can I repair or reacknowledge the drive within UCSM or do I have to reboot and try to do it after the BIOS boot up?  Thanks.
mfrase
When pulling drives, or swapping between systems, the LSI array controller can put the drive and/or raid configuration into an inactive state. From past experience, this occurs, roughly 50% of the time. We currently do not have a policy to place drives/raid into an active state. I believe this has been filled as an enhancement i for the UCS.
In order to re-activate the drive/raid, they need to reboot and get into the LSI option rom and re-activate the drive and/or raid configuration.
Without looking at the LSI screen, I’d suspect one of the drives in the raid-1 (mirror) has been disabled from the removal process. They just need to re-enable it.
Mike & Dave
