Reset 6454 FI currently in Intersight mode.
stolischris
Hello Team,
Trying to rename a FI via intersight site but there is no option for that.
I guess, I need to reset them but I cannot issue the connect local-mgmt command, sais not available.
Any help will be deeply appreciated.
RedNectar
Hi @stolischris ,
When you have configured a Fabric Interconnect for IMM, I believe you need to issue the erase-configuration command without issuing a connect local-management command first. Here is how it is described by the help command:
UCSX-A# help
Commands:
  cd                             Change the directory to the allowed directories
  change-domain-name             Update the name of the Fabric Interconnect and the Peer FI
  change-mode                    Change the manageable mode of server
  change-password                Update the password for the admin user of the Fabric interconnect
  clear                          clear the screen
  clear-firmware-cache           Clear an entry from the Intersight firmware cache
  clear-sshkey                   Removes hostname/IP Address entry from known host lists
  cluster-start                  Start cluster server(for initial HA setup)
  connect                        Connect to an endpoint
  cp                             Copy a file from local/remote to remote/local filesystem
  erase-configuration            Erase configuration on Fabric interconnect
  exit                           exit the program
<snip>
I wasn't at liberty to test this on my system, so be sure to let us know if it works.
RedNectar aka Chris Welsh.
