09-29-2022 08:50 AM
Hello Team,
Trying to rename a FI via intersight site but there is no option for that.
I guess, I need to reset them but I cannot issue the connect local-mgmt command, sais not available.
Any help will be deeply appreciated.
09-29-2022 01:21 PM
Hi @stolischris ,
When you have configured a Fabric Interconnect for IMM, I believe you need to issue the erase-configuration command without issuing a connect local-management command first. Here is how it is described by the help command:
UCSX-A# help Commands: cd Change the directory to the allowed directories change-domain-name Update the name of the Fabric Interconnect and the Peer FI change-mode Change the manageable mode of server change-password Update the password for the admin user of the Fabric interconnect clear clear the screen clear-firmware-cache Clear an entry from the Intersight firmware cache clear-sshkey Removes hostname/IP Address entry from known host lists cluster-start Start cluster server(for initial HA setup) connect Connect to an endpoint cp Copy a file from local/remote to remote/local filesystem erase-configuration Erase configuration on Fabric interconnect exit exit the program
<snip>
I wasn't at liberty to test this on my system, so be sure to let us know if it works.
