08-17-2016 10:05 AM - edited 03-01-2019 12:51 PM
Is there any way to check Rx\Tx power , voltage counters and so on on IOMs?
I can check the info on the FI ports, but not on the chassi's IOM:
(nxos)# show interface transceiver details
Ethernet1/1
transceiver is present
type is 10Gbase-SR
nominal bitrate is 10300 MBit/sec
Link length supported for 50/125um OM2 fiber is 82 m
Link length supported for 50/125um OM3 fiber is 300 m
Link length supported for 62.5/125um fiber is 26 m
cisco id is --
cisco extended id number is 4
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature 44.16 C 75.00 C -5.00 C 70.00 C 0.00 C
Voltage 3.24 V 3.63 V 2.97 V 3.46 V 3.13 V
Current 6.02 mA 10.00 mA 2.59 mA 8.50 mA 3.00 mA
Tx Power -2.21 dBm 1.69 dBm -11.30 dBm -1.30 dBm -7.30 dBm
Rx Power -3.13 dBm 1.99 dBm -13.97 dBm -1.00 dBm -9.91 dBm
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
I checked some CLI commands in the mode 'connect iom ...', but didn't find anything useful.
08-30-2016 08:51 PM
Hi ,
You can use the below command to check the SFP status on IOM ::
fex-1# show platform software woodside sfp 0 ni1 >>>> NI1 is the NIF (network interface port)
0-NI1 : : SFP (A0) Info:
## SFP Info:
SFP FP-Port : 0
Fcot Num : 0
Fcot Type : Not Found
SONET : No (Bytes 4-5)
Ethernet : No (Byte 6)
FC : No (Bytes 7-10)
## Error: This SFP has no transceiver codes defined.
SFP Type : None
Min/Max Speeds : [1094792522, 1129271377] Mbps
>> BASE ID FIELDS <<
Bytes Name Value
0 Identifier : 0x03 (SFP Transceiver)
1 Ext. Identifier : 0x04
2 Connector Type : 0x21 (Copper Pigtail)
3-10 Transceiver : 0x00 0x00 0x00 0x00 0x00 0x04 0x00 0x00
(4-5) - SONET ComplCode: 0x00 0x00 (None)
(6) - Eth ComplCode : 0x00 (Reserved)
(7) - FC LinkLength : 0x00 (None)
(7-8) - FC TxType : 0x37 (None)
(9) - FC TxMedia : 0x00 (None )
(10) - FC Speed : 0x00 (None)
11 Encoding : 0x00 (Unknown/Unspecified)
12 BR, Nominal : 0x67
13 Reserved : 0x00
14 Length(9m)-km : 0x00
15 Length(9m) : 0x00
16 Length(50m) : 0x00
17 Length(62.5) : 0x00
18 Length(Copper) : 0x05
19 Reserved : 0x00
20-35 Vendor Name : CISCO-MOLEX
36 Reserved : 0x00
37-39 Vendor OUI : 0x00 0x09 0x3A (00093a)
40-55 Vendor PN : 74752-9047
56-59 Vendor Rev : 0x30 0x37 0x20 0x20 (07 )
60-62 Reserved : 0x01 0x00 0x00
63 CC_BASE : 0x10
>> EXTENDED ID FIELDS <<
Bytes Name Value
64-65 Options : 0x00 0x00 (None )
66 BR, max : 0x00
67 BR, min : 0x00
68-83 Vendor SN : MOC14362896
84-91 Date Code(Y/M/D) : 2014/09/09
92-94 Reserved : NA
95 CC_EXT : 0x9D
>> Base ID Fields - Raw Hex Dump <<
Word 0 1 2 3
00-03: 03042100 | 00000000 | 04000000 | 67000000
04-07: 00000500 | 43495343 | 4F2D4D4F | 4C455820
08-11: 20202020 | 0000093A | 37343735 | 322D3930
12-15: 34372020 | 20202020 | 30372020 | 01000010
>> Extended ID Fields - Raw Hex Dump <<
Word 0 1 2 3
16-19: 00000000 | 4D4F4331 | 34333632 | 38393620
20-23: 20202020 | 31343039 | 30392020 | 0000009D
Access=Ok, A0 CC=Ok, Security Check=Ok, A2 CC=Ok
most of the outputs are some coded values not sure how much they are useful to you..
Thanks-
Afroz
****Ratings Encourages Contributors ****
09-01-2016 12:49 AM
Yeah, I looked here, but didn't find anything useful.
