02-09-2022 11:34 PM
Is there a command that i can run and get the fan status and fan serial number for a
Cisco UCS 5108 AC2 Chassis?
I need to identify the inoperable one and also its cisco serial number.
Thank you
Solved! Go to Solution.
02-10-2022 07:44 AM
Found it, in case someone else is searching - https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ucs-manager/CLI-User-Guides/System-Monitoring/3-1/b_UCSM_CLI_System_Monitoring_Guide_3_1/b_UCSM_CLI_System_Monitoring_Guide_3_1_chapter_01011.html#task_2DCCDCB084BC4FD5A7F8192BD285A26E
The following example displays information about fan module 2 in chassis 1:
UCS-A# scope chassis 1
UCS-A /chassis # scope fan-module 1 2
UCS-A /chassis/fan-module # show detail
Fan Module:
    Tray: 1
    Module: 2
    Overall Status: Operable
    Operability: Operable
    Threshold Status: OK
    Power State: On
    Presence: Equipped
    Thermal Status: OK
    Product Name: Fan Module for UCS 5108 Blade Server Chassis
    PID: N20-FAN5
    VID: V01
    Vendor: Cisco Systems Inc
    Serial (SN): NWG14350B6N
    HW Revision: 0
    Mfg Date: 1997-04-01T08:41:00.000
02-09-2022 11:46 PM
- Check if this thread could be useful : https://community.cisco.com/t5/unified-computing-system/how-to-use-the-command-display-all-serial-number-on-cisco-ucs/td-p/2061079
M.
02-10-2022 07:44 AM
Fan Module:
    Tray: 1
    Module: 2
    Power State: On
    Presence: Equipped
    Thermal Status: OK
    PID: N20-FAN5
    VID: V01
    HW Revision: 0
