Some questions regarding using SREs
Devake666
Dear All,
I'm considering to monitor some packet traffic as well as detecting any router issues with a customized application deployed on a SRE module on a ISR G2. However i'm still not quite sure about the following issues:
1, Will it be possible to send the traffic to the other router ports as well as the SRE module via the MGF? I will need to send the traffic to the application on the SRE and also to any devices connected to the router.
2, Is it possible to throw SNMP traps to the SRE on the router via MGF?
3, Other than using addition CPU resources, are there any other differences between using a ESM and not using a ESM to access the SRE?
Any help is deeply appreciated.
Angus
Robert Burns
Angus,
This is the Unified Computing forum.  This question would be better suited in the Service Provider or Network Infrastructure section.
Robert
