SPF Model at the switching side ...
Hi folks,
In the "UCS-C220 M3" side, we are using the 10-GE SFP+ Module "CDE2-SFP-1WSR" (for Intel X520 Dual Port 10Gb SFP+ Adapter), so we want to know wich "10-GE SFP+ Module" we have to use in the Switching side (for Cisco Nexus 7700)??
The only details that I have about module "CDE2-SFP-1WSR" is that "SFP+, 10-GE SR Optical Module, 850 nm (fiber)"...
Thanks in advanced
Gregorio
Kirk J
The PID for 10Gb 850nm, sfp would be the common SFP-10G-SR.
You might want to check the spec sheet for the particular 7700 line card you are using, just to be safe.
Here's a good link to book mark for transceiver interoperability: http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html
Kirk...
