Start up Inventory issue
AL5555
hi
I have installed the Cisco UCS Emulator 5aPE1. I added couple severs, chassis..etc and initial setup from start up inventory panel. The issue is that the chassis is not discovered neither on the UCSM nor on the topology view ? has any one faced this ? please advice .. thanks
Keny Perez
Level 8
Level 8
you are more likely to get a better answer here:
https://communities.cisco.com/community/technology/datacenter/compute-and-storage/ucs_management/content?filterID=contentstatus[published]~category[ucs-platform-emulator]
Upper right-hand corner.... Create > Discussion.
-Kenny
Saurabh Kothari
how many chassis have you configured?
is it more than 14? then it is likely to fail!
if not then did you restart the UCSPE?
Restart Emulator with this Hardware SetupRestarts Cisco UCSPlatform Emulator to enable the emulated Cisco UCS Manager to discover the new hardware inventory configuration
-SK
