test connectivity between FI and SAN
Amr Hafez
could i do fc ping from Fabric interconnect working in fc switching mode and if I could please tell me how ?
and if I could not how can I check connectivity between FI and Netapp storage
thanks
make sure you enabled the FC zonning at VSAN profile.
Ahmed
Walter Dey
Hi Amr
What is your configuration ?
Netapp storage connected directly to FI with FC ?
or
Do you have a FC SAN ? and if yes, what kind of switches ?
Walter.
Hi Walter
Netapp FAS 2552 7mode connected directly to FI 6248 with FW 2.2(3c) in FC SW mode using FC SFP 8 G in both sides
the physical connection such in the attached pic 1
the configuration on FI:
1- create 2 vHBA in each server for both paths FI-A and FI-B
2- create zoning
vHBA FIA --> both WWPN of both ports of controller 1 of Netapp target
vHBA FIB --> both WWPN of both ports of controller 2 of Netapp target
those done for each blade
Ahmed
Amr
Check your setup against
http://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-infrastructure-ucs-manager-software/116082-config-ucs-das-00.html
Walter.
