THICK LAZY refuses to persist on HX Data Platform
Cannot make THICK LAZY virtual disks on the HX data platform using every trick in the book.  Thin and Thick eager work like a charm. Even when I migrate and convert disks to thick lazy it displays the correct new settings but after creation or migration-conversion the virtual disks ALWAYS come back as thick eager. When you create thick lazy they complete instantly and appear to work but when you double check the VM they are indeed showing as thick eager.
See log captures of my tests below.
Thanks!!!
getsmit
http://cormachogan.com/2012/09/14/esxi-cannot-distinguish-between-eagerzeroedthick-lazyzeroedthick/
