Ucb B VFI Paths unpinned down and nexus side waiting for flogi
We have issue with connecting Fi to Nexus . 1 link is use for Fi - server and 1 link is for Fi to nexus . and configuration is :
Fi to nexus :  Fcoe vsan 100 and with ether channel , and ether channel and port is up and operational state is ok
but flogi of my server is not send to nexus ,and flogi data base is not update . int  error is :
 N55k-1 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel17: Ethernet1/5 is up
 N55k-1 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel17: first operational port changed from none to Ethernet1/5
 N55k-1 %ETHPORT-5-IF_UP: Interface Ethernet1/5 is up in mode trunk
 N55k-1 %ETHPORT-5-IF_UP: Interface port-channel17 is up in mode trunk
 N55k-1 %PORT-5-IF_TRUNK_DOWN: %$VSAN 100%$ Interface vfc20, vsan 100 is down (waiting for flogi) CONNECT TO BLAde A
 N55k-1 %PORT-5-IF_TRUNK_DOWN: %$VSAN 1%$ Interface vfc20, vsan 1 is down (waiting for flogi) CONNECT TO BLAd
in the other side  vfi uplink for eth0 is down  unpinned
for fc 0 in unpinned ,  up
any idea ???
my vsan is 100 and fcoe vlan id is 100 on ucs
and in nexus , trunk port between nexus and ucs is e 1/5 with port channel 17 .here is my configuration
N55k-1(config-if)# sh run int vfc 20
!Command: show running-config interface vfc20
!Time: Mon Jun 29 12:28:19 2020
version 7.1(4)N1(1)
interface vfc20
bind interface port-channel17
switchport trunk allowed vsan 100
switchport description CONNECT TO BLAde A
no shutdown
vsan database
vsan 100 interface vfc20
N55k-1(config-if)# sh run | sec vlan
feature interface-vlan
vlan 100
fcoe vsan 100
name FCOE100
vsan 100 interfaces:
vfc20
