UCS ARP ? issue
jason.harlow
Having trouble tracking down why this might be happening....
So we have a UCS chassis with fabric a and fabric b (two 6248's) with management IPs clustered
x.x.x.4 = fab a
x.x.x.5 = fab b
x.x.x.6 = cluster IP
The management ports are plugged in to a separate HP 1gig switch.
For this example A is primary.
Upstream they are connected to two nexus 5548's.
From the "outside world" (i.e. my desktop coming in through the hp switch), I can ping all three addresses just fine.
However from my VMWare hosts on the Cisco UCS blades, if I go through a NIC on fabric A I can only ping .4 and .6. If I go through Fab B, I can only ping .5
All other hosts on that VLAN work fine over both fabric A and B, it's just the management ports on the 6248's.
8 Replies 8
richbarb
Hello Jason,
For sure this is something outside the UCS scope.
How your HP switch is connected to 5548??
Try create a vpc to connect a HP management switch with two nexus 5548, this vpc should allow the management vlan, that also should be configured in the UCS domain down to each vnic interface that you need it.
Richard.
I thought that was what was configured, but apparently was wrong. Only nexus A was connected to the HP switch.
However, when I created a vpc and enabled across both switches, now I can't connect to anything on the management network from the UCS blades. Everything looks up / ok on the Cisco and HP switches but no traffic is making it over.
The VPC is configured with identical VLANs as when just the single nexus was connected.
I tried with both LACP mode active and on.
the ports are spanning-tree type normal and show a status of forwarding. Scratching my head why this is not working.
Nexus A:
interface Ethernet1/1
  description "HP SW Int 42"
  switchport mode trunk
  switchport trunk allowed vlan 1,101
  speed 1000
  channel-group 20 mode active
interface port-channel20
  spanning-tree port type normal
  speed 1000
  vpc 20
Nexus B:
  description HP SW Int 44
  speed 1000
  speed 1000
  vpc 20
HP Switch:
ProCurve Switch 2510G-48(eth-44)# sh lacp
                           LACP
   PORT   LACP      TRUNK     PORT      LACP      LACP
   NUMB   ENABLED   GROUP     STATUS    PARTNER   STATUS
   42     Active    Dyn1      Up        Yes       Success
   44     Active    Dyn1      Up        Yes       Success
interface 42
   name "Trunk to Nexus 5k"
   lacp Active
exit
interface 44
   lacp Active
vlan 1
   name "DEFAULT_VLAN"
   untagged 1-24,26,28,30,32,34,36,38,40,45-48
   ip address 172.20.0.200 255.255.0.0
   tagged 42,44
   no untagged 25,27,29,31,33,35,37,39,41,43
   exit
vlan 101
   name "NEW_MGMT"
   tagged 42,44
   exit
Originally, Nexus A simply had eth1/1 connected to HP port 42 and Nexus B eth1/1 was shutdown
half working nexus A config was :
  speed 1000
HP VLAN config was untouched, port was just not LACP.
# sh vpc
vPC domain id                     : 1
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : success
vPC role                          : primary
Number of vPCs configured         : 5
Peer Gateway                      : Enabled
Peer gateway excluded VLANs     : -
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Enabled (timeout = 240 seconds)
vPC Peer-link status
id   Port   Status Active vlans
1    Po1    up     1-2,101-104,200-201,1000-1001
vPC status
id     Port        Status Consistency Reason                     Active vlans
15     Po15        up     success     success                    102,200-201
16     Po16        up     success     success                    102,200-201
17     Po17        up     success     success                    101-104,200
        -201,1000
18     Po18        up     success     success                    101-104,200
        -201,1000
20     Po20        up     success     success                    1,101
The really strange bit (and why I suspected that it's something in UCS) is that when I only have a link between Nexus A and the HP switch, everything in VMWare over both fabrics can get to everything ELSE on the HP switch that's on that VLAN.....just not the fabric interconnect management port for the other fabric.
Example:
(route based on originating port ID is used here so that I know all traffic for a VM is going over a particular vmnic)
VM 1: Can ping 10.1.101.4 and 10.1.101.6 (Active fabric interconnect + cluster IP)....get network unreachable errors for .5 (FI B).
VM 2: Can ping 10.1.101.5, but not .4 or .6
Both of those VMs can ping/connect to everything else that's directly connected to the HP switch on VLAN 101. 10.1.101.4 and 5 are both also directly connected to the HP Switch.
We are having the exact same issue, did you every find a fix?
Could you please post a network diagram of your setup.
If I understand you correctly:
Out of band management IP address is on the same vlan / ip subnet as your VM IP addresses.
management is out of band, VM communication is inband !
do you have Northbound Ethernet Uplinks to the HP switch, in addition to the management connections
Can you please post the mac address tables on the two FI's as well as the HP switch ?
Hello
Could be due to
CSCun19289
FI mgmt0 dropping traffic coming from blades behind that FI
Are you initiating ping to FI mgmt interface from a VM hosted on UCS blades ?
Padma
Thank yoiu for your response.  CSCun19289  is exactly what we are running in to.  We just went to 2.2(1c) this weekend and started having this issue.  We will implement workaround for now.
Matt
