UCS B200 M3 and M4 same Chassis
richardin
We need to know if we can put a B200 M3 in the same chassis as our B200 M4 blades? I have seen that the M3 is limited on the firmware update compared to the M4's. Would that be an issue?
Wes Austin
Yes, you can add them to the same chassis. They can run different firmware versions, as long as they are supported by the UCSM release.
Check the release notes for UCSM for further info.
Wes Austin
