UCS C22 M3 NTP Offset?
chrisnenzel
I'm having issues with the NTP setting on the C22s we purchased.  I can configure NTP just fine through the CIMC but it defaults to UTC and I need to set the offset to -8 for PST so that the system Clock is accurate.
The documentation I've been able to find says to ssh into the CIMC type scope system then scope service then set the offset but the scope system command doesn't work.  Neither does the GUI instructions that I've found which say that the offset is in the Admin tab of the CIMC.
Anyone have any insight as to how I can set the NTP offset?  For now I've disabled NTP as having it off by 8 hours will play havoc with my VM's on boot.
Thanks!
padramas
What happens if you change the time in BIOS to match your local time and then enable NTP ?
Does it stays synced with NTP source ?
Padma
I'm running into the same issue (UCS C-220M3, Cisco Business Edition 6000). After my research I am afraid NTP Offset is not supported at all when the server is managed directly via CIMC (rather than UCS Manager).
The Menus/Commands the OP mentioned are from UCS Manager.
Cheers
David
