UCS c220 M3S after replace Raid Controller and battery, there is beeping sound : 1 sec on and 3 sec off
jaruneesup
Dear all,
I am now running on UCS c220 M3S running BiOS 1.5.1g and CIMC firmware 1.5.1b.
There is a LSI MegaRaid 9266-8i (Firmware 23.9.0-0023) controller
After replace Raid Controller and battery, there is beeping sound : 1 sec on and 3 sec off without any error.
How do I solve this problem?
Brian Morrissey
Sounds like you are running into the following bug https://tools.cisco.com/bugsearch/bug/CSCuf24540
kelvinffhan
Hi Jarun,
May I ask you some question?
After you replace the raid controller, would you need to reconfigure the Raid Configuration?
Would you facing any Data Lost? eg. the VM lost?
Appreciate if you can reply me. Thanks.
You are not supposed to lose any data and you dont need to reconfigure anything... metadata will rebuild anything that needs to be rebuild unless you lost more HDDs than your RAID config can tolerate, like a RAID 5 losing more than 1 disk.
HTH,
-Kenny
