UCS C220 not recognizing LSI 9266 MegaRaid card
jinewman
I just received a new UCS c220 with a seperate LSI 9266 MegaRaid card. I have installed the card adn connected the SAS cables and BBU.  When I start the server it doesn't recogize the card.  If go into CIMC the card is not listed.  I have changed the SAS cables and resetted them all several times. I have resetted the card several times.  I have not changed any of the settings yet so I may be missing something there that will make it recongize the card but I have followed all available instructions as well.  Any thoughts on what I could be missing?
16 Replies 16
Just for info, I have had the same issue with LSI 9266 controller on UCS C220.. requested RMA and the new one was working right away.
richb1971
Level 4
Level 4
I had similar issue. Faulty motherboard resulted in RMA - new server did not have PCI Slot 2 enabled hence no Megaraid. These posts helped me fix issue :)
