UCS c460 & Cisco 12G SAS Modular Raid Controller for C460
jdempsey460
I am unable to select the virtual device on RAID as a boot device.
We have just installed the kit, and I configured 2 VD's, and selected 1 as a boot device, then installed OEL6.7 onto this device.
Then when requested to reboot, the server cannot find the 2 VD's, even though it displayed "2 virtual drives found on host adapter".
I have disabled all slots in "LOM and PCIe Slots Configuration" menu, except for Slot ID: SAS, which contained this RAID controller.
What do I need to do next?
thanks
john
Keny Perez
Level 8
Level 8
Can you please go to CIMC>BIOS> config BIOS> Advanced tab and get an screenshot of the Option ROM?  I want to see all of them... if you choose to disable them all and then enable one of them while the "disable all" is still set, it wont work.  The proper way is to enable all and then disable the individual ones that are not supposed to be used.
-Kenny
