UCS Central Blade Firmware Package
Damon Howell
Is there a way to build a custom blade firmware package and distribute it?
The companies standard for this quarter is 2.2.3b for the blade firmware, but there are newer M4 blades with controller cards that require a firmware version newer that 2.2.3b.  In UCS Manager, we can build a custom firmware package that excludes the controller card from being downgraded.  It looks like I cannot import and use the custom firmware package in UCS Central.  Does UCS Central support custom packages, or can it only publish/use Cisco defined firmware packages?
Damon Howell
Products used:
UCS Central version 1.3.(1a)
UCS Manager 2.2(3a) - Blade firmware 2.2(3a)
Also tested with UCS Manager 2.2(5a) - Blade firmware 2.2.(3f)
