Jeremy Waldrop
Level 4
Level 4
Firmware 1.4(2b) fixes the thermal and fan issues.
We had to power cycle the chassis to clear the issues up (not something you want to have to do in a data center) .  The I/O module is fine and the fans are normal again.  My thoughts were a code issue too, but the "fix" code is only a couple weeks old...
It is a very stable release, I have updated 4 of my customers to 1.4(2b) and haven't had any issues.
FYI there are a couple of fixes in this release for these problems.   I believe the problem you are describing is related to this, which is part of the release discussed.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtl43716
