UCS : Power Management : fence agent :Intersight
flamegri11ed
OLVM requires fence agent setup for power management
All listing of Service Profiles in the Cisco 6296 environment with B200M3's were testing fine.
Listing Service Profiles : fence_cisco_ucs --ip='10.16.16.80' --username='fence-kvm-user' --password='fence password' --ssl-insecure -o list
fence_cisco_ucs --ip='10.16.16.80' --username='fence-kvm-user' --password='fence password' --plug="iscsi_kvm11" --subor
g="/org-B200M3clusteboot/" --ssl-insecure -o status -v
In the B200M5 (5108 and UCSx) environment with Cisco 6454, I have created a local fencing agent username and password and this has been attached to the Service Profiles. The attempts for a listing of service profiles in the domain using the above older UCS listing (-o list) does not work as I get error unable to login/connect to fencing device.
I am assuming Cisco Intersight(4.2(3e)) and UCS Manager(4.12b) connections/login are different and a different approach is needed.
Any advice would be help
Thank you.
  • --ip: The UCS Manager IP address
  • --username: The login name for the fencing user in UCS
  • --password: The password for the fencing user in UCS
  • --plug (--port in older releases): The UCS service profile name, as found in the service profile listing
  • --suborg [optional]: The sub-organization for the UCS service profile"
8 Replies 8
Brian Morrissey
Can you use the ipmi or redfish fencing options instead and point towards the CIMC IP of each node?  You are correct about the cause as the fence_cisco_ucs uses the UCSM XML API and the creators of that script would need to modify it to use Intersight APIs.
Thank you Brian . I will add the fence_redfish agent and test it and report the outcome.
The default switches for username and password and - status does not reveal anything atm.
Thank you for the information.
My Redfish attempt from the Oracle KVM server :
[root@kvm ~]# fence_redfish --ip='10.16.16.80' --username='Oracle' --password='password' --systems-uri=/redfish/v1/Systems/FCH221122CS --ssl-insecure -o status
ERROR: Unable to get PowerState: https://10.16.16.80:443/redfish/v1/Systems/FCH221122CS
Its the first time that I get a response and related to power. The Ovirt/OLVM power management requires it. Not sure if the uri"uri=/redfish/v1/Systems/XXXXXX" is correct for B220M5 blade power status.
Any advice to conquer Redfish would help.
Thank you.
Cisco Intersight Managed Mode Configuration Guide:  uses the IPMI policy with a local user with a local user role and Service Profile IP to achieve the(power management) fencing option-fence fence_ipmilan. Is this correct in saying this would be the right route to take on the B200M5's considering that the old option of "fence_cisco_ucs" no longer works ?
Correct, either fence_redfish or fence_ipmilan using the credentials defined in the local user policy.
For fence_redfish the URI that returns powerstate is /redfish/v1/Systems/<Serial#>, you can try curl from that machine to make sure its receiving a proper response back
curl -u username:password -k https://cimc_ip/redfish/v1/Systems/Serial#
Thank you Brian.
I could achieve that response by enabling Redfish on our C220M4 by doing curl -u username:password -k https://cimc_ip/redfish/v1/Systems/Serial#
I got the access denied message however on the B200M5 blade on the new Intersight environment.Not sure why using the Service Profile IP and local user with "admin" equivalent(which i assume must be user role only)
The access denied might be firmware related as redfish wasn't exposed to users initially in IMM mode, I'll see if I can track down when exactly redfish support was added in IMM but it should work on 5.1(0.230073) and higher.  On older versions like 4.2(3e) I get the same access denied.
If 4.2(3) is a requirement then the fence_ipimlan would be the solution
fence_ipmilan --ip='172.16.16.80' --username='Oracle' --password='password' --lanplus -o list: Test status = ON (powered on)
Task : Create new IMPI policy (user role only) with previous attached local user policy (already attached to service profile for previous attempt at fence_ucs testing-no longer valid with ucs intersight)
