what is the upgrade path for our current releases (4.0(1a) for UCSC-?
sacapano
hi we are trying to upgrade at least to 4.1(3n) , I would like to know what would be the latest stable version that you recommend and what is the upgrade path for our current releases (4.0(1a) , 4.0(2b) and 4.1(3d)) ?
for
UCSC-C220-M5SX.
Consider the ‘golden start’ version on the Cisco portal as the stable version.
In the release notes, there is a section titled ‘Upgrade Paths to Release 4.1’. Please refer to this table. The upgrade path for the mentioned versions to 4.1.(3n) will be a direct upgrade.
Response Signature
7 Replies 7
It would help if you were to tell which product your question relates to?
Response Signature
Hi Roger its , UCSC-C220-M5SX.Thanks!
Thanks for updating your original post. As this is not related to anything within the Collaboration area I’m moving your post into the UCS Data Center area.
Response Signature
Response Signature
